I'm trying to track down a a type of switch. Basically it consists of X amount of buttons and only allows one to be pushed down at a time. You push one down and the other pops up.
The switch will be used for a passive speaker selector in a studio.
The name you're looking for is "ganged"
See Surplus sales
See Surplus sales
"ganged" usually applies when all the switches move in unison. This more usually in a rotary switch with ganged wafers that all turn together, or a ganged multi channel pot where all the wipers move in unison.
The interlocking push button latch switch with self cancelling action must have a generic name, but just at the moment I am stumped.
They were very common for tuning radios, car radios in particular, but also any pre digital tuner that had preselected channels.
Most are only for low current duty, so do specify your special high current duty.
Naah there is a name... I can kinda see the sign in one of our electronics shops... Except I dont have photographic vision...
Nordic said:Naah there is a name... I can kinda see the sign in one of our electronics shops... Except I dont have photographic vision...
Switchcraft calls them "multiple station switches."
se
Thanks that's great help. Are there any good sources in the uk?
4most are a great supplier but don't do the 'ganged' switches
Piano-Key switches.
Early radios had a long row of them, also range selection in DVMs etc.
'Can't find a UK supplier, though 🙁
Sorry I cann't provide a link, but this description could help you find what you are looking for. Hopefully.
I bought some from Maplin years ago - they don't seem to sell components anymore.
Made by Alps, the individual switch sections could be inserted into a metal "U" shaped carrier with cutouts to accomodate the switch sections. This carrier was available with cutouts for two, four six etc spaces for switches. The switch sections were available in two pole, four pole & six pole changeover versions. A small wire widget (for want of a better word) could be inserted under a plastic cover for push on - push off action like a retractable ball point pen, or pushbutton mains switch. Without this widget it had momentary action. A flat bar, provided with the "U" shaped carrier and with cutouts for the switches, slid along the carrier and provided latching action to the momentary switch. When one switch was pressed, the others were released by the movement of this bar. It's this carrier with the sliding bar that you want, together with the appropriate switches.
Phatriff said:Thanks that's great help. Are there any good sources in the uk?
Don't know of a direct source but Farnell sell sells some of the Switchcraft 65000 and 67000 series multi-station switches which they get from US stock from Newark (they have a GBP15.95 per order charge for that).
se
These things are made up to own spec. the mounting bars and switches are bought separatly. as are the interlocking bars and spring assemlies.
most of this type of switch are lowish current types and may not be suitable for speaker switching.
brands from memory are Devlin, EMO, Alps
farnell do a range, http://www.farnell.com/datasheets/61068.pdf
rs no longer stock them (i think)
hope this helps
bob
hope this helps
bob
Nice work. Thanks
The speaker selection is occurring before the amp so it should only have to deal with levels of about 2.5volts max.
Farnell Australia only has a few Devlin parts left, interlock bars and brackets mostly, no buttons and no mechanisms that I can find.
They carry some similar looking ALPS switches but no interlocking accessories.
Did you have any success Phatriff?
No luck i'm afraid. The final spec required gold contacts which i couldn't find on these latch switches so i moved to a rotary switch design instead
If you have the ability to do so, use a Basic STAMP module with it and use momentary switches. You will need to know the coding language though…and I'm busy coding my own projects, and have very little time to write the code for this.
Hint: You will need relays - lots of relays. 😀
That'd be my suggestion as well (though I'd go with an AVR, of course). This sort of switching mechanism has been obsoleted by digital controls for years, or built-to-spec for specific applications. They'll be hard to find and probably prohibitively expensive. It probably wouldn't be hard to cannibalize a source selector kit to do what you need if you don't want to write the code.DJ Exprice said:If you have the ability to do so, use a Basic STAMP module with it and use momentary switches. You will need to know the coding language though…and I'm busy coding my own projects, and have very little time to write the code for this.
The other option is to use set/reset (dual coil) latching relays. These accept a 'set' or 'reset' signal on different pins which turns them on or off respectively. With some diodes you can wire this so that the press of a button resets all the relays except the one of interest, which gets a set signal. It gets ugly with more than 5 or so inputs though since you need n^2 diodes and connections.
Yeah. Things CAN get ugly. If you don't mind, you can just have a transistor as a switch instead of a relay. It really just depends on what you're doing/sending signal to. If it's for an amplifier input selection, well, just see if you can come up with your own solution. Relays could work. Maybe transistors? Somebody explain the best switching mechanism before I hurt my own head!
Actually, with respect to electrical switches, all ganged means is "side by side". It's a very old and common term used indicate that all switches are withing the same box. Anybody ever read the side of a receptacle box. They usually indicate whether the box is gangable. In fact, Leviton states that the total capacity of their switches (wattage) drops if they are ganged in one box. The reason is due to heat. Anyway, this is what it means when used in the elecrical contractor world. It's also referenced in the electrical code books.
- Design & Build
- Parts
- What is this type of switch called?
