What is the Universe expanding into..
Do you think there was anything before the big bang?
  • I don't think there was anything before the Big Bang
    Votes: 56 12.5%
  • I think something existed before the Big Bang
    Votes: 200 44.7%
  • I don't think the big bang happened
    Votes: 54 12.1%
  • I think the universe is part of a mutiverse
    Votes: 201 45.0%
  • Total voters
    447
Regarding your views on sentence structure, it's not a rule, merely a general guideline.
A complete sentence must include a verb and make complete sense standing on its own.
It is unarguable that "After supper." makes no sense standing on its own!
A sentence that does not contain a verb is called a nominal sentence. These are relatively uncommon in the English language.
"What a great day today!" is a nominal sentence since it does not contain a verb. It's complete form is "What a great day it is today!" where "is" provides the verb.
Pete's so-called "sentence" can't even be placed in the nominal category!
The Moon is constantly facing the same side towards Earth, because of an imbalanced iron core that makes it function somewhat like a giant compass needle.
The Moon is known to have a dense metallic core comprising of a small solid inner core surrounded by a liquid core.
It is thought that in the distant past rotational dynamics produced a "dynamo effect" which may have produced strong magnetic fields, evidence of which are recorded in lunar rock samples.
I can't find any reference to the Moon having an imbalanced or unbalanced iron core.
However, I have found this, dated June 2021: Is Earth’s core lopsided? Strange goings-on in our planet’s interior. | Berkeley News
For reasons unknown, Earth’s solid-iron inner core is growing faster on one side than the other, and it has been ever since it started to freeze out from molten iron more than half a billion years ago, according to a new study by seismologists at the University of California, Berkeley.
By that part of the definition there are some entire books that fail to contain a single sentence.
Then those books, by definition, are badly written. 😉
I've looked at your link: Moon model - An offset core. - NASA Technical Reports Server (NTRS)
In the proposed model the Moon has a core whose center is offset from the center of the outside spheroid towards the earth. Such a core will be formed if the Moon were entirely molten at some time in its past, and on solidification was synchronous with the earth.
Searching for "offset core of moon" takes me to this link: NASA's Cosmos
It appears that the Moon's centre of mass is offset by 2 kilometres from its geometrical centre.
So far, however, I can't find how this correlates with the fact that "The Moon is constantly facing the same side towards Earth."
Can you help come up with that correlation?
I'll mix in fluid dynamics, and simplify.
A vast meteor strikes a massive lump of liquid rock. Fast forward to the after effects of the impact: Cue two molten orbs with spin, the heavier elements slowly sink to the individual centers while the lighter elements are supplanted towards the surfaces, the heavier elements have a stronger pull towards the other orb because of magnetic fields being strengthened by the internal friction heat. Weight and magnetic fields of the heavier elements attract and fight against the spin that threatens to distance the two orbs. The offset of the center slowly cause a stronger braking effect and eventually a lock in spin when the smaller body solidifies more rapidly than the larger.
Edit:
Like holding a bowl filled with water and rocks, start spinning around and the lighter water will move towards the edge of the bowl and perhaps even spill. While the heavier rocks are impacted more by gravity than spin.
So on the moon the iron core will be closer to the centre of gravity and the lighter rocks will move towards the outer edge of the spin.
Wouldn't surpise me if a tidally locked Moon goes a bit, er, egg-shaped... 🙂
The classic culprit is Jupiter's moon Io. All sorts of things going on there, including an elliptical orbit that whacks it with heating tidal forces:
Io (moon) - Wikipedia
By some weird coincidence, I was testing my knowledge of the 31 "Mysterious Moons of the Solar System" on this monstrously clickbait but interesting site:
Mysterious moons of our solar system
Io and the Moon came first and second. But all the usual suspects are in there.
I was really hoping for a published reference, KaffiMann.
You would have to wait until they manage to find enough funds to do a thorough dissection. Fact as we kow it so far: gravitational center is offset from geographical center. The end.
Am I to take it that you believe that the Moon is not spinning?
I'll give you the boring answer: Depends where you stand. 😀
It is after all personal to you, right? 😛
Your post did, at first, appear personal to me since it was my post which preceded yours.
I reconsidered that in my edit.
However, it became more personal to me when KaffiMan, bless his little Norwegian socks (or lack of), decided to teach me the rules of English grammar! 😱
All is now hopefully in the past, and I am now in a more copacetic mood! 😀
