It totally depends on the actual drivers, waveguides etc. For example typical hgh-frequency horn's acoustical center is furter back than of a typical cone woofer's if both are placed on the same front baffle buth a typical bare dome tweeter's acoustical center is forward of a typical cone woofer's.
Typically 5/8" to 3/4", approximate for small woofers, and dome tweeters.Question is like the title.
I like to know how much delay should typical be necessary.
Here's some information I gathered a while ago. The first few paragraphs are a response from Ben (@wolf_teeth) when I asked him. The "Jeff" Ben mentions is Jeff Bagby.
Thanks for nice answers.It totally depends on the actual drivers, waveguides etc. For example typical hgh-frequency horn's acoustical center is furter back than of a typical cone woofer's if both are placed on the same front baffle buth a typical bare dome tweeter's acoustical center is forward of a typical cone woofer's.
What is more correct is to talk about the 'acoustical centers'.
I guess this understood.
What I get from your answers this distance should be between 15 and 25 mm.
18 mm is a good mean value. Will mean 52 uSec delay.
System in my mind is 1" tweeter and 7" wooofer in a two-way.
The pioneer's conclusions presumably from both anechoic (Bell Labs) and free space measurements (~84"h*80w*40"d reflex horn w/wings).
Thanks. Sorry, I haven't actually applied the info in any of my projects yet.
I just recently became aware of the paper, from a seemingly credible source, and passed it on.
Best success!
Best success!
"forward of woofer"? No. From one of the references:
"Practically, what this means is that one will have to offset the tweeter (i.e. move it back)."
The tweeter is smaller and faster so it needs to be set back.
See: https://en.wikipedia.org/wiki/Loudspeaker_time_alignment
Agree great paper !Great paper.
155 uSec delay gives 55 mm distance beween acoustic centers.
This seems a lot more than previous poster tells.
It is a lot more because it is not the same delay when you use a passive crossover and an active crossover with the same drivers. I don't know really why.
I notice the delay is not the same with a passive crossover and an active crossover.
For 8" + 1" It is near 6/6.5cm. But I recommend to measure the distance with an acoustical measurement system.
IMHO how to find acoustic center offset (at any frequency) should be a homework exercise -- one-liner -- using only a tone generator (and the ruler). Once this has been done for each driver and they are physically offset time-aligned, the XO can then be (more simply) designed and similarly adjusted to ensure phase-alignment around each overlap region, for coherent sound, best transcients and deep soundstage.
Please use our search function: LX acoustic center, by wchang (method in the summary, and many applications). LX is only the technique; the speaker can be stepped-baffle. Or, the OP can DSP the delay given the measured offsets.
Not precisely, but 33mm +/- 5 (even 1mm off, 9° phase for 8.5khz, makes a significant audible difference by the LX method).
My experience is about 1.2" given a 5" woofer and dome/ring radiator using interferometry (moving delay in simulator until they match)
- What is the typical distance tweeter is forward of woofer in two-way speaker
