What is the power rating of the Peavey 300SC output BJT???
back when i had a pile of them, i used MJ15022 and 23 transistors for "general replacement" output devices on guitar and PA amps. the 15024 and 25 have better max ratings than the 22's and 23's, so if i had my 'druthers, i would use them, but don't use one to just replace one transistor of the output set, replace the whole set. you will need to readjust the bias, but otherwise, they should work fine, maybe even better than the originals.
