Hi there,
A real quick question from a newbie. What size drill bit should one use to make holes (on a heat sink) that are suitable to be tapped for M3 screws? It seems that I can only find drill bit in imperial scale? Would a 1/8 (0.125) inch drill bit work for the M3 (0.118) ? Thanks!
Lo_tse
Lo_tse
Thanks for that, copied it to my pc.
Dont forget to oil the hole the tap will go down to ease the cutting.
I broke two taps before finding that out !
for a 3mm x .5 pitch fastener;
as noted use a 2.5 mm drill, or a close equivalent is a #40 drill.
The Fractional Drill Chart reference
Drill/Tap chart reference
Hi Maybe this will help.
Ian
Thanks! That's useful. Here in Canada, it seems that I can only find drill bit in Imperial size (e.g. Home Depot) but not metric. Using you chart, may be I should try 7/64 inch (2.75 mm) drill bit for the M3 (3 mm) screws.
Sure - You can give 7/64 a try on a scrap piece to test how it goes with a tap and fastener. Aluminum being soft be careful to not over torque the M3 fasteners and strip out the hole.
Otherwise go down a fraction and test that too. That's how I would proceed on my stuff.
Remember the tap lube as nigelwright7557 noted. Have a spare tap....
Heat sinks are usually made out of a gummy aluminum that likes to break taps and machines poorly. If you're going to do much of this, it pays to order drills and taps from a machine tool supplier. For taps that cut threads in blind holes, order spiral flute taps (not spiral point) as those will send the chips back out the top of the hole. Spiral point taps will send the chips forward, but they have to have a place to go. Those are the only two styles one should mess with. For something a bit nicer, order a Balax forming tap. You'll need a very specific (and larger) drill size, but the tap will form the threads by deforming the aluminum. No chips at all and very strong threads. The taps are much stronger than cutting taps and last near to forever. In any case be sure to use oil for both drilling and tapping. Vegetable or animal oils work best so if you don't have a commercial tapping fluid, try a bit of canola oil or bacon grease!
Thank you very much for the link. Very comperhensive information!
Thank you for the info and advices. I do have a set of taps purchased from a hardware store, but have not tried it out yet.
Your point on using the spiral flute taps is interesting. I thought, like drill bits, taps would pull the chips back out on top! Good to know. I guess I just have to get a scrap piece to try things out.
Once again, thank you very much for all the info and advices. Much appreciated.
Lo_tse
Lo_tse
Metric threads have been made easy for us since they adopted a 60degree thread face angle.
Take the screw thread size and subtract the pitch.
eg M3 0.5mm pitch needs a 2.5mm drill.
In hard materials (steel) you can drill slightly bigger than 2.5mm to make for easier tapping and this gives slightly less engagement.
In softer materials (aluminium) you can drill slightly smaller than 2.5mm to ensure full engagement of the male and female threads.
The extreme form of this are the thread forming taps, rather than the thread cutting taps.
Note "slightly".
The total engagement of that M3 0.5mm pitch is only 0.25mm. Take 10% off that for 0.225mm engagement results in the required hole size being 2.55mm diameter. 80% engagement requires a 2.6mm diameter hole.
Poor drilling technique and poor sharpening of the drill point both result in oversize holes.
Be careful you leave sufficient engagement to give a "strong" thread.
Note "slightly".
IOW don't use the 7/64 drill as it will leave too little material to form threads of adequate depth. If you can't find the 2.5mm go with either a #40 (slightly undersize) or a #39 (slightly oversize).
7/64" drill = 2.778mm.
The 7/64" drill will measure very slightly smaller than this, possibly around 2.765 to 2.773
This leaves far too little engagement.
If you drill oversize due to errors then you could have almost no engagement.
Kevin is right !!!!
Kevin is right !!!!
I have a related question: what size drill should I use to make a hole to pass an M3 screw? Exactly 3 mm, or larger?
In metric, I always drilled the hole 0.8 of the M size. The respective bits are readily available in hardware stores from Metriclandia.
For example M3 drill with 2.4mm, M4 drill with 3.2mm....
Gentlemen,
Thank you for all the pointers. Much appreciated.
To make a hole for taping, is a dress press absolutely necessary (I know it is much easier) or can one get by with a cordless hand drill?
Lo_tse
Lo_tse
Gentlemen,
Lo_tse
A hand drill might not drill a straight hole so a drill press is much better.
However, I have got away with a hand drill, I was just carefull to keep the drill steady.
A worthwhile thread to read
http://www.diyaudio.com/forums/pass...rad-heatsinks.html?highlight=drilling+tapping
If you only have a hand drill you can get the closest to square drilling by placing the upright edge of a small engineers square next to the center puched mark for the hole. Use the vertical edge of the square as a reference to keep the bit aligned vertically in both the side to side & fore and aft planes. A drill press would produce a better result but you can get close with practice.
- Design & Build
- Construction Tips
- What drill bit size to use?
