Transistors do age -- because of heat which can cause failure, and the types of plastic and plasticizers used to encase them which break down over time
Oh, that aging. Yes, resistors and cables age too (oxidized).
Hearing ages too into your golden 👍ears. Do we believe the old posters and sellers here who say they can hear small details that others can't?
Can you tell us more about that method?
My point was about awareness of the same situation as discussed in IT books. If we are aware of the situation we will not easily believe everything and we will tend to do validation efforts. Simple thing is to read old posts from a member to know his background. We may also develop a list of members with good ears, members with bad ears who always say any amp sound good, etc. etc. 😀
Threads about opamps (and resistors too) are gold mines for me. Who, and what people say about the sound of opamps. Mostly what i see are people who do not know that opamp sound depends on the implementation but there are a few who know exactly what they are talking about.
Yes, I know who I can believe. Some people think that a measurement from an audiolgist is important, but no, it doesn't work that way. Like many measurements are just irrelevant with the issue being studied.
If you hate "grain" in your sound, but are a lover of Haribbo Gummi Bears, then take four such Gummi Bears and put them under the feet of your DAC.
Then, take yet another set of such Gummi Bears, and place them under the feet of your amplifier.
Most probably, the "grain" will be much less of a nuisance.
If you do not eat Harribo Gummi Bears, try soft squash balls, cut into two halves.
One squash ball ==>> Two supports for your audio equipment.
the mother bat can listen and locate her young among thousands
of them screaming inside a cave, when I knew about this I found it miraculous. It's the human ear so sensitive?, I don't know but I feel it's more
than we think.
BR
than we think.
BR
Still no citing of trusted validation method.My point was about awareness of the same situation as discussed in IT books. If we are aware of the situation we will not easily believe everything and we will tend to do validation efforts. Simple thing is to read old posts from a member to know his background. We may also develop a list of members with good ears, members with bad ears who always say any amp sound good, etc. etc. 😀
Are you sure it doesn't work that way? I wonder what validation method you used to arrive to that conclusion.Yes, I know who I can believe. Some people think that a measurement from an audiolgist is important, but no, it doesn't work that way. Like many measurements are just irrelevant with the issue being studied.
Are you sure it doesn't work that way? I wonder what validation method you used to arrive to that conclusion.![]()
Don't worry about me. Just make sure you have a good one 🙂
You are the one who stated it doesn't work that way. The onus is on you to back it up.Don't worry about me. Just make sure you have a good one 🙂
What backup you are requesting? Measurements? I'm here just to share what I'm willing to share (and there are things that I won't). Mostly, our listening skill is quite independent of the existence or the ability to hear the highest frequencies. If we lost all of our hearing, we can't implement our knowledge and skill. But listening skill is mostly related to audio below 10kHz. It's fine if you lose the top octave(s), but it is a big problem if you lose the lowest octave!!
😀 you are very right ... some sounds are very harsh by nature ... if the system makes them less harsh is taking out/veiling something 🙄
not true to the original i mean
Unless you were there at the mastering/mixing process of the recording, unfortunately you don't know what the original was in order to judge what it's being true to...
If a naturally harsh sound is too distracting from the whole, an engineer somewhere along the creative chain will likely take the decision to remove that harshness.. or maybe general limiting is introduced for something more automated.
You can risk making choices that end up compensating for that creative choice and end up with an overly hard system when playing more natural material... but then blame the recording.
Good to make your own recordings ..
However, subjectively, I sometimes notice a sort of dynamic sonic loudness kind of grain, just as you describe. Grain equating to sounding granular. This can be an especially noticeable effect with quiet, or distantly miked instruments, which can seem to abruptly rise and fall above and below the threshold of being plainly audible in the mix, rather than do so smoothly in a natural live sound sort of way. Or, conversely, seem to rise and fall too much or too abruptly in loudness, which can also be describes as sounding grainy.
So I guess a sort of gating effect, or negative compression (there's a better term for that, I can't think of).
Or a non-linear gain that quickly increases after a threshold.
So it turns out that you made things up when you stated "Some people think that a measurement from an audiolgist is important, but no, it doesn't work that way."What backup you are requesting? Measurements? I'm here just to share what I'm willing to share (and there are things that I won't). Mostly, our listening skill is quite independent of the existence or the ability to hear the highest frequencies. If we lost all of our hearing, we can't implement our knowledge and skill. But listening skill is mostly related to audio below 10kHz. It's fine if you lose the top octave(s), but it is a big problem if you lose the lowest octave!!
Unless you were there at the mastering/mixing process of the recording, unfortunately you don't know what the original was in order to judge what it's being true to ...
Hi ! you are very right of course ... but some labels like for instance Ma Recordings are dedicated to make recordings very true to the original.
I have seen a video on Youtube that fascinated me a lot indeed.
This is the link
YouTube
what amazes me most are the comments of listeners at the end. Some actually preferred the recordings played-back on a very good rig to the original 😱😱😱
That would be fantastic ... sometimes i read something that makes me dream about music reproduction like these words ...
I found it disorienting to slip the headsets on and be immediately transported into the acoustic of the chapel—which makes me wonder how the characters on Star Trek can handle transporter beams with such aplomb. Ah, the wonders of bad acting. It sounds silly, but I'm not kidding. Putting on the Nova Sigs took me so totally into a different space that it was confusing. Of course, microphones hear differently than do ears, so Steve and I were getting a hyper-detailed picture of what was going on in the chapel—which is exactly the point of a monitor system. We found it distressingly easy to hear Albuquerque's street sounds, buses, motorcycles, and air traffic. But that allowed us to stop the take and resume when we were confident that things were silent. Confident—that certainly is the right word.
Read more at Stax Lambda Nova Signature electrostatic ear-speaker Page 3 | Stereophile.com
more real than real ... wow 🙂
Another one that hit me immensely ...
When I listened to my own voice, as recorded on The Ultimate Test CD (out of print), I was taken by surprise at how the Antares put me—not just my voice—in my own room, nasal twang and all, without added colorations. It was an out-of-body experience
Read more at Rockport Technologies Antares loudspeaker Page 3 | Stereophile.com
skem,
topology and orthogonality are of central importance here.
Two oppositely directed forces of similar strength create an unstable-metastable state. It includes a nonreactive orthogonal coupling to the driving magnetic field resulting in heavy signal loss (loss of all even order spectral components in addition to the losses occuring for various other reasons).
Stability has an unexpressible continuous magnitude, "settled" is not a very accurate assessment. After phase compensation, the amplifier becomes usable, but remains largely unstable, exhibiting poor high frequency response and high distortion.
By convention, only the (unexcited) ground electronic state is considered to be stable.
Orthogonality does not apply to signals. Signals cannot be treated analytically.
Carbon has superior general and high frequency properties, Allen Bradley carbon composite resistors being (one of) the very best. The high static noise and lack of precision play a subordinate role, it is signal handling that matters. Of course, any noise has a harmful impact on the signal.
It seems to sound that way. I think that your use of the term "compression" may not be far away from the objective mechanism. Perhaps, it is caused by the dynamic behavior of a signal's distortion spectra. I wouldn't think that the output signal's amplitude is in error to any overtly audible degree. However, that's only a supposition which may be incorrect, particularly, since harmonic distortion is due to an amplifier's gain not being perfectly uniform across all input signal amplitudes and frequencies.
This is the link
YouTube
"No matter how good the sound system, there will be some lost". Some people are trained to hear what was lost and some are 'trained' (actually you don't need to be trained for this) to hear what was not heard.
He said "a quiet guitar and vocalist is one of the hardest things to realise...." Really, I thought it was often used in demos because it's one of the easiest things to realise.
- Member Areas
- The Lounge
- What causes grainy sound
