What 18" driver would you choose for a dipole?
Powered by say a Hypex FA501.
Around 300 Euro or less.
I've been eye'ing:
B&C 18TBX100 and RCF LF18G401
I've been eye'ing:
Have you considered the resonance frequency of this kind of enclosure? It's dependent on the depth of the cavities. An 18" will push the resonance down to around 150Hz. If the openings are small (like you have drawn them) compared to the depth the resonance will have an elevated Q (meaning peaky) and you typically have to cross over well below that, e.g. 80Hz.
The other concern is that if you use one 18" driver in this kind of setup there will be a lot of vibration. Better would be two 15s operating in opposite directions. Is there any particular reason why you want to use a single 18?
Anyway, if you were in the US I would recommend this driver:
IB3 Series - IB318 v2 | Fi Car Audio
I'm not sure how expensive shipping would be to your location, but it's probably not cheap. The driver does fit within your budget.
Hi Erik,
They are to augment my open baffle Bastanis. (I have active sub 15" closed box) But I want to add the 18 inch dipole subs as Bastanis offers already. I just don't have the moolah to get the "official" units.
The current subs are set to a low pass 90Hz. So these will be similar.
Basically because it is a proven concept for the bandwith it is aimed at. See pic of the dipoles Bastanis sells.
Basically what Bastanis designed them for. I made my baffles for the widebands a little wider...so 80Hz seems fine to me.
If the magnet vent cannot breathe, stick the magnet through a hole in the cabinet panel. A and B in your image do not have to be equal.
Note that pro audio woofers are not designed to have silent motor ventilation. They might chuff. Probably they will chuff, because turbulence improves heat transfer.
Hi Bas,
For not too much money, after having simulated a lot of drivers with AJHorn for OB (but not necessary ripol) applications, the Eminence Delta pro 18-c gets my vote, although I have to admit that I never tried this driver in reality, but a few others. This would be my next one to try wouldn´t I have my AE18.
Groetjes
Mattes
The parameters of the peerless 18" look like it's incredible value. Probably would get one if I had to start all over again.
But having bought an A&D R1524, which is 15", I know I really don't need more cone area, or displacement volume. That thing hardly moves!
18" Peerless or 15" SB, if I had to choose again.
