I have a thin mini-itx based Windows 10 media PC that I built. aS part of the build I installed an IR remote control for Media Player. At first I used the audio outputs from the (Asus) mobo. The remote function (using an HP remote handset) worked as intended with Media Player, Kodi, Skype etc.
I then decided to experiment with using an outboard DAC. So I bought a Twisted Pear "USB Receiver/DAC" http://www.twistedpearaudio.com/digital/usb.aspx . The remote control functions still worked as intended when I used the audio outputs from the DAC Receiver board.
I then connected the coax SPDIF output from the TP USB Receiver/DAC to a separate DAC. The SQ improved but the remote control will no longer control the volume or mute functions. It will however, still stop/pause/skip tracks.
I don't understand why this should be. Surely the USB output from the PC is the same no matter what DAC is connected. The remote handset is not at fault as I have two and both behave the same.
Can anyone shed any light on why this should be happening? Thanks.
https://www.ti.com/lit/ds/symlink/pcm2706.pdf page 17:
You should configure your SW player to use software volume instead of volume control offered by your audio device..The digital volume control does not affect the S/PDIF and I2S outputs (PCM2706/7).
"You should configure your SW player to use software volume instead of volume control offered by your audio device.."
Thanks very much for your quick reply. I now understand why I'm not getting the remote control of the volume/mute functions, but I can't find any options/setting to do what you suggest. Can you offer any more detailed advice?
