Weird Drivers Catalogue
looking at the Matin monitor reminded me of these Audio Nirvana's
Eminent Technology fan woofer:
Bozhen woofer and tweeter:
This woofer has 2 motors/coils, and works very similar to the LAT from Tymphany in opposed motions.
The tweeter has a conventional voice coil, and a suspended diaphragm by way of rods from coil to surface. Looks and operates like ribbon, but very low HD and conventional VC.
Another rod-coupled unit, Heil Transar:
Morel weird woofer, on the left below:
Adire Parthenon, 6" to 12" scalable Xmax. Springs are both suspension and tinsel leads. 24" plate pressurized the room:
Phoenix Gold Cyclone was a waveguided approach to rotary woofers in a horn construct. 2 orifices with a spinning flat membrane from the center. Weird to watch:
Tymphany LAT woofer (250/500/700 models; 250 pictured in my NEHD design), dual opposed motors and rod driven membranes:
Airblade:
I WISH I COULD FIND THE KOVE!! It literally had a large surround as the diaphragm, and had a small tweeter shoved into the middle. It was mid '90s to mid '00s time frame, and car-audio targeted. Limited to about 600Hz on the bottom. It looks a LOT like the Fibona driver below... EXCEPT that the Fibona is a rigid membrane, and the Kove was basically a surround.
Fibona:
JVC offset former woofer:
FAL driver, or larger FAL-C driver, meant as full-range:
Manger dual-voice-coil bending wave driver, heard them once and was not impressed:
Morel Powerslim Integra, a convex coaxial:
What Pepe posted is about a 10" equivalent Cerwin Vega DOME woofer, FWIW.
Later,
Wolf
Vance Dickason did a Test Bench article...
Bozhen CQ76
https://audioxpress.com/article/test-bench-an-updated-cq76-ribbon-tweeter-from-bozhen-new-audio-lab
CurtC used it in a design with dual Rival woofers.
Rick Craig was known to use it a lot, and did one with the Purifi. AFAIK, he was the US distributor, and they ran about $175 each.
company website:
http://www.bzspeakers.com/ribbon76_en.html
and newer slightly larger and lower reaching edition CQ76B:
http://www.bzspeakers.com/ribbon76b_en.html
The Poly-Planar P40's, made almost entirely of styro-foam. Used these in a pair I built 30 years ago. Put them in a 1.5 cu/ft box with a 10" passive radiator on the rear.
Worked out well considering no TS parameters available. I really liked the sound and received many good comments from friends.
A friend in the 70's had a Yamaha guitar amp (TS 60, I think) which had two rectangular speakers with styro-foam cones.
I liked the sound so much I wanted to buy the amp just to use the speakers on my stereo.
So when the P40's came along, I had to give them a try.
