Why do all the browsers seem to suck these days?
Chrome won't work with Twitter now so I moved my passwords out of Google and into Bitwarden.
Yes, I know Adblock is blocking some of Twitter, but first off: it doesn't work if I turn it off, Secondly: If your site doesn't work with ad blocking, I won't use your site.
If I go to a news site that has a "paywall", I just disable Javascript for that domain.
Brave can't set actual location and crashes if you click a "Google Pay" button.
Firefox can't set a speed dial as it's home page, and extensions like mouse gestures don't work on built in pages (can't open a new tab with a mouse gesture on the home screen).
Opera is annoying and unstable last I used it.
Edge is MS and I'm just not interested.
Epiphany kind of sucks.
So now I'm running Vivaldi and so far so good. They even have an Android version so I've created a Vivaldi account to sync devices... Maybe I'll finally be able to have ONE browser instead of five...
First string, iCab, second string, FireFox & Safari. Each has its strengths.
And it may not be the browser, it could be the coding of the website.
dave
dave
Two of three of those are Apple specific, the other doesn't work properly as per my post 🙁First string, iCab, second string, FireFox & Safari. Each has its strengths.
dave
If I knew, I'd fix it... Clearing the cache doesn't seem to do anything, either... Version 103.0.5028.0 (Official Build) dev (64-bit) on Manjaro GNOME.I use Chrome, and twitter seams to work fine for me. What happened?
jeff
You have a recent Win update? I had one recently, and Chrome wouldn't even launch. Had to run the dism utility in the program dir.
jeff
jeff
Sorry, I should have been specific.
I'm running Chrome version 103.0.5028.0 (Official Build) dev (64-bit) on Manjaro GNOME.
I have just confirmed it does work on version 101.0.4951.54 (Official Build) (64-bit)... It seems then to be an upstream bug or an extension that doesn't play nicely. Still, I was trying to move away from Chrome in the first place hence why I went to Bitwarden for password management.
I used to think using a password based on CRC32 with a site related hint in the middle was secure. Apparently it can be cracked in seconds... I use much stronger passwords now, but I can't remember them all.
Example...
I used to use something like 8d6cdiya2f1a for DIY audio but 8d6caudia2f1a for Audio Asylum ... (not real passwords, but the same standard)... I could remember them all.
A new password looks something like t7o%t@z&QA9mx@iYavfA$v
Good luck remembering that LOL
Example...
Maybe it isn’t the browsr but the OS?
dave
Nope.
It was (apparently) an upstream problem in Chrome.
The other problems aren't "problems" as much as pet peeves.
On Android, I have the same problem with keyboards... Could becomes Le because it missed me drawing the first half of the word... Suggesting words with no context but not the ones that fit, etc.
https://www.security.org/how-secure-is-my-password/password based on CRC32 with a site related hint in the middle was secure. Apparently it can be cracked in seconds... ... like 8d6cdiya2f1a for DIY audio
"It would take a computer about 33 thousand years to crack your password"
Allowing for Moore's Law, that may be 24 years. But by then CrackBook will tell the KGB-CIA all your secrets before you know them.
Also:
https://www.enzoic.com/password-check/
The first site tests for 'hard-to-break' (but has quirks for very short words). The second site tests for 'has this been seen in cracker dictionaries?'; if it was exposed in a compromise then it will be tried again by hackers.
It's because they aren't web browsers any more. They are execution environments designed by competing committees. They have risen to the level of operating systems in themselves, complete with process/thread schedulers, resource management and more. As we all (should) know, OS development is hard and we are standing on the shoulders of giants by using Linux.
People need to recognise that they aren't "browsing the web" any more, they are running random code downloaded from multiple and perhaps untrustworthy servers.
Personally i use noscript on both firefox and chromium on my desktop machine (devuan or antix). Android browsers are so broken i'm stuck using an old version of firefox also with noscript.
I was going by this: I was a little off lolhttps://www.security.org/how-secure-is-my-password/
Also:
According to that first site, my new style of password would take 200 sextillion years to crack 🙂
So after a few days of Vivaldi and everything working, geolocation went out.
Firefox doesn't want to work with geolocation anymore either...
So now I'm on Opera again... I have a feeling it's a problem with geoclue... OTOH, Vivaldi support says geolocation doesn't work in Linux or MacOS (but it worked for a day or two).
I have tried hard to like brave, but I have several extensions that silently stops working, critical extensions like session managers or security extensions etc is not good, and the browser itself seem to getting clogged up after a day so can only kill the process and start over again, ff seems to be much more stable but eats a lot more memory as if theirs a memory leak (clearing up memory under url address about:memory remediate it only fractionally). But yes, as mentioned I have had instances where I need two different browser to handle one thing, for example brave at least in my linux configuration can't save pdf files properly from important web sites because it screws up the internal file name or whatever it is, not the one seen in the file manager, so another website where I need to upload the pdf to complains the file doesn't have a file name which is just a mystery, and there have been many buggy things going on with both my main browsers and some other programs since ubuntu started to force several programs in a so called Snap package format (they silently replaced both my browsers with this other package format and other programs), being linux this forceful overreaching behavior is not a good sign and apparently got a lot of criticism.
Not sure what you mean by geolocation? If you mean the browser knows where you are by your IP, that never works as IP location is nonsense...So after a few days of Vivaldi and everything working, geolocation went out.
Both of those show completely incorrect locations for me, one seems based on IP (the first one) the other seems totally random - who knows what it thinks it's doing. But that's what I would expect, there's no location info that they can find - I'm on private unlisted wifi, IP location gets it wildly wrong...
For me, the first one shows my location within 500m in Opera, but there is NO location at all with Vivaldi or Firefox... I get "Geolocation: Position unavailable - Share your location to load the Where am I map" but the browser says the site is accessing location.
In all browsers, the second shows an IP based address that is in Ottawa (I'm in Toronto).
- Member Areas
- The Lounge
- Web Browsers
