I would say that this piece is better it therms I point in the previous post?
but You could save some space putting the different angle from bigger verticall
horn, that will allow the central horn to be attached directly, without the connecting part
or connecting part will be little bit more hidden from the front view.
If the dominant shape is elipsoidal, like central driver horn has,
maybe is good let the bass horn to have a little more of that shape?
if it is not complicated too much to do itin practice...
somehow i knew that it is some educated designer not to have notion about the total outfit of the stereolay example.🙂
but it could be corrected not a big deal.
Somehow we are forgetting the fact that when we going in the court we ultimately consult professional, not standing alone. Or when we going to the dentist?
Imagine what could be happened that we ask wife or doughtier to repair our tooth?
(Ex wife will probably take out few more then asked...)🙁
cheers
cheers
Autotech group buy
Hi I was wondering if there is any status info on the last group buy from autotech?
Thanks Jon
Thanks Jon
Thanks Jon
Were you part of it? The pallet arrived around a week ago.
Thanks Jon
I've got about 6 of the Iwatas still left to package up. I should have yours done in a couple days.
THats what I meant to be asking. I have my new hybrids layed out. With IWata profile on the sides and JMLC on the top and bottom.
hi jzagaja, could you please tell me about the 2" iwata-300 with 1.4" optional reduction? Is the reduction a separate add on piece for the 2" horn? I have'nt decided which driver to use, but if I ordered the 2" iwata with optional reduction, I was hoping I could experiment with both voice coil sizes. Thanks.
-Nate
-Nate
Jzagaja, do you happen to know the exit angle of Faital Pro comp drivers, specifically for their 1.4" drivers? I'm trying to find out if they're compatible with SEOS waveguides.
Hello everyone,
These SEOS looks impressive, I hope it sounds great too !
I would like to know if the SEOS 12 is/would be available in solid surface (resin) ?
The SEOS 15 seems to be the only horn in the SEOS range to be available in this form but I don't need to cross much lower so the SEOS 12 is perfect for me and the directivity seems a "bit" more wider/better controled than the SEOS 15.
Thanks in advance for your answers and returns of experinces,
Stephane.
Stephane.
Both SEOS-12 and SEOS-15 are available in resin (solid surface). They are heavier and cheaper.
Thank you !
Is there any difference sound wise between the fiberglass version and the resin version ?
Instinctively I'll say that the resin horn is "better" because more mass=better dampening=less resonances, but with a well made and well calculated horn it should be negligible.
- Group Buys
- Waveguides and horns
