Wavecor 2 way
I made an educated guess. This was not modeled, and further tweaking could be in order. If the midrange is a bit shouty, step up to a 2.5mH.
I attached it here for a preliminary network based on Dan's posted work over at MAC.
The inductance is less on the 4 ohm, so more tilt will be required, so I increased the L1 to higher than half the initial value, as well as not halving the tweeter resistor for this reason. Nothing saying you couldn't give it a shot and adjust/tweak as necessary. Again- this is an educated guess, and no harm or ill-intent is meant, however, it may not be optimal.
Couldn't hurt to try it....
Having second thoughts on using the scanspeak tweeter, due to cost, paired with the Wavecor. I would like to find a second choice that will cross low and work with the WF223BD01 since I have these drivers on hand. What about the Wavecor TW030WA12 ?
