Warning! Valve shattered inside a Belton VT9-PT socket
yes, like Kevin said, i also use a defective tube on fresh sockets....i have broken a few good tubes before....i have lots of tubes that if it breaks i will not lose sleep about...
also when soldering sockets to a board, i insert a tube first to get them alinged prior to soldering, soldering with tubes inserted is good too...
I am restoring a Dynaco ST 35 that I have bought Belton sockets for and I used Russian tubes for output. The pins that are on Russian tubes are thicker, I have noticed that it is hardly possible to get the pin into the holders.
I became curious then discovered that all 7-9 pin tubes from ussr have slightly thicker pins, I took apart my sockets and opened up the upper part of the hole on the base it became much easier to put in the tubes now.
