360 V at the center tap, but how much at the anode and how much at the cathode ?
The difference between these two voltages is the actual anode voltage.
Presumably at little over 300 V, which is not excessive.
The most important thing is to take care that the power dissipation is in the allowable limits, about 12...13 W / tube.
These things you must ensure by measurements.
