visaton g25ffl with or without wg148r
thank you very much, but i do not use boxsim so i can not open the project file.
i have the waveguides, i bought them to be used with seas 27tff but they where a poor fit, maybe they will work better with a tweeter it is designed for, but one can not be sure
I was curious enough about this to look into fixing that waveguide to myriad tweeters:
SoundImports | "Wave guiding" your favorite tweeter. - SoundImports
Now something there doesn't add up, because AFAIK, the 27TFF and the 27TFFC have the same front plate. 😕
But it seems you just drill new holes in the plastic waveguide and use woodscrews:
XT25 + Visaton WG 148 R with pictures
Can't be hard, can it?
the fit between waveguide and tweeter front plate is poor with seas 27tff which gives a quite poor frequency response, my hope is that the visaton tweeter has a better match, some measurements could show this
thanks, good to know! 🙂
i just did some dirty measurements on some tweets, laying on a thick rugg facing upwards with handheld mic at roughly 0 / 30 / 60 degrees and 20cm distance
maybe i should get a pair of dxt to try out
