Vintage professional and military wiring
Tek
It’s interesting to see how they do it , all so tight. Almost impossible to service
It's called Proper Lead Dress, and is incorporated into how the unit is layed out, designed.
Sadly, in many cases, it's a jungle, and not very "serviceable-friendly".
However, back when "vintage stuff" was manufactured with real quality in mind, servicing was hardly ever needed.
My 1963 RCA Victor console stereo's preamp/tuner chassis was a mess to service, and even the servicing documents contained warnings about how certain parts and wires were to be dressed for good reliable operation.
Have a look at the chassis and you'll see what I mean.
But isn't modern solder, with silver instead of lead, ok anyway? The issue is that the solder inserts in the ceramic required silver to bond.
Ceramic_Strips
I think it is a lovely story that a ceramics loving company employee, Ted Goodfellow, could have felt sufficiently empowered to develop a radical approach for electronics construction. Wish I worked at a company like that!
Ceramic_Strips
I use modern solder without lead it works great on these ceramic terminals none have cracked when I have solder them.
Not sure the problem is *cracking* but solder layer on ceramic must be atoms thin.
Best case microns thin.
Silver will dissolve in plain solder, same way as soldering iron copper tips do, leading to pitting.
You have soldered those maybe once or twice.
In the not so long run, silver plating will disappear and plain solder you use now will NOT stick to bare ceramics.
Tek avoided that by supplying silver saturated solder, so it would not absorb any more.
