Vintage Amp Repair closed?
Can you use a matched pair of 2sk170's N JFETs in place of the 2N5566?
certainly yes, taking care of differences - Idss and max Uds
if LTP - biased with CCS (either active or resistor), difference in Idss is no issue
increased xconductance leading to increased OLG
anyhow, that's where you can try stash of 2SK170GR Toshibas you have
though, there you can apply all 2SK246Y you have ...... almost 100% drop-in replacement regarding Idss, while xconductance higher enough than you don't need to worry about amp behavior
Hello folks, I am still here working hard to keep old equipment up and running. I have had quite the drama with keeping my .net web site, so recently went to onbizmap.com and facebook. Visit that if you would and help it get moving. I get many scam calls, please leave a good message.
Hi Jon,
Is your business contact info available? I own a forte model 3 and would like to inquire regarding upgrades.
Thanks,
James
