Vifa P21WO-39-08 Woofer - Sealed
Ashok,
The XO freq. is not selectable. it is fixed one its done.
The supply voltage is 15v. I have the neccessary opamps
for the input volume control, the schematic as well.
The op-amps are Burr-Brown OPA2134.
The whole setup is sitting on a vero board. If getting the
PCB made is not difficult I'll do it.
I'd appreciate if we could take this out of the forum
as we've deviated quite a bit.
ph:
(res): 5496268
(off): 51383464
sunil
Was busy.
Hi Sunil ,
I was rather busy with other projects. I will get back to you by Sunday with a solution for your problem.
I have a board ( design) with almost what you want. I was trying to see if I could alter it to make it more flexible and with on board pots to set level. So hang on for a day or two.
Cheers.
