Is anyone using these drivers? I am interested on some opinions on sound quality for music and for HT.
Also, I would love some suggestions for a tweeter that would match up nicely to this driver.
Thanks,
Thanks,
Milzie said:Noone?
Give everyone a chance, the forum has been effectively shut down for the last 2-3 days.
Can you dig out a URL to the driver so that everyone doesn't have to go digging to figure out exactly which driver you are talking about.
dave
> mg18sk09-08a
Its response graph is pretty ugly right in the region where your ear is most sensitive. I wouldn't want to use this much above 300 Hz.
What is your target application?
dave
dave
Looking for an affordable sheilded driver for home theater that is available in both 4 ohm version as well as 8 ohm
I know the response graph isnt pretty, but that doesnt always mean a speaker sounds bad.
Milzie said:Looking for an affordable sheilded driver for home theater that is available in both 4 ohm version as well as 8 ohm
Is your plan MTM for L, R fronts & MT for rears? and you'd like to keep to 4 ohms (Ms paralleled) or 8 ohms (Ms series)?
Yes this is VERY true, but here with the stiff cone, the early break up & the early roll-off off axis, things don't look really good for it having a sweet midrange response.
dave
Im looking to keep it 8 ohms all the way around. So two 4 ohm drivers in series in each front, and one 8 ohm in each rear.
Milzie,
did you end up using the Vifa MG driver and if so what were your thoughts on it?
Planet10,
I can't see why you say that the response is ugly? To me it looks quite flat!
It has a narrow dip just above 1khz of 2db, pretty minor. Then above that dip the response is up about 2db before its upper rolloff.
I would consider a response like that one that doesn't need any eq at all. How many drivers are smoother than this? (yes I know the Vifa P13 is smoother, yet it has early rolloff.
Perhaps I am mistaken ...
What about the Vifa MG14?
Above about 1.5khz the response drops down a little, and I wonder if this could be a good thing given the sensitivity of the ear in this range. This would result in a more laid back sound I imagine, and give less listening fatigue ... any thoughts?
regards,
Paul
Planet10,
regards,
Paul
- Vifa MG18SK09
