What about this one?Yes of course this is always available since this chassis is a standard product https://modushop.biz/site/index.php?route=product/category&path=324
Think two of these are necessary.......for mono block use. Also, standard product?
Sorry for disturbing the VFET chassis thread!
If font panel covers heatsinks it is only a plus in production version. I like the quality of these and the look.
That's the 4 heatsink version (2 per side):
https://modushop.biz/site/index.php?route=product/product&path=324&product_id=885
Ok, thank you so I just had to go one step deeper and I can customize with either 2 or 4 heat sinks.
Maybe a picture of both 2 and 4 heat sink versions at "top-level" and 2. level below would be good?
Only 3rd and last level revels all the "good stuff" 🙂
Sure I have plenty of pictures of this chassis. Tomorrow morning as soon as I am back to my office I will send you some 🙂
The model with 2 heatsinks (not 4) has a front panel which cover the whole front surface of the heatsink
I can see all the pictures when I just click all the way into the selection of 2 or 4 heat sinks.
It was just for your web it could be nice to also view the 4 heatsink version at "top-level".
I left the page again using your first link you provided as I did only see the 2-heat sink version as I thought it was the only option.
tg123 2I was the fortunate winner of the Sony VFET essentials kit auctioned yesterday at BAF22. So, naturally, I immediately contacted Gianluca of Modushop to beg for a chassis - like the gorgeous limited run done for the lottery. Gianluca amazed me by replying at what must have been the closing time of the bar opposite Burning Amp - in the wee, small hours…
Gianluca, who I hope will see this and confirm the following, said he would be prepared to do a small production run for a minimum of ten chassis. He suggested we start a thread and that is what this is - a list of interested parties prepared to commit to buying one or more VFET chassis from Gianluca. I am not offering to head up a Group Buy but simply hoping we can get to ten or more chassis orders here and then contact Gianluca with orders.
Name / Number of chassis wanted
derekr 3
Never mind. Don’t add me to the list. It seems that the Tokins won’t work well with this chassis.
derekr 3
ranshdow 1
chromenuts 2
OtisCampbell 1
Kannan_s 1
rtan 1
derekr 3
ranshdow 1
chromenuts 2
OtisCampbell 1
Kannan_s 1
rtan 1
Can I be put back on that list pleaseName / Number of chassis wanted
derekr 3
ranshdow 1
chromenuts 2
OtisCampbell 1
Kannan_s 1
rtan 1
Someone grabbed what looks like an improperly modified list with my name on it.
I decided to use Mini Disspante I already have…see post #100.
In the interest of clarity this is the list of those interested in purchasing as of today. If anyone is not on the list please add your name. Conversely, if you're on the list but wish to be removed, please post below.
derekr 3
ranshdow 1
OtisCampbell 1
Kannan_s 1
Winyl 2
Eddie18 - 1
claudio52 - 1
ARGOS - 2
CritterSoft - 1
rtan 1
When Gianluca has deemed sufficient time has gone by he will post on this thread announcing orders can be placed at this link:
https://modushop.biz/site/index.php?route=product/product&product_id=887
Hope that sums it up to date....
derekr 3
ranshdow 1
OtisCampbell 1
Kannan_s 1
Winyl 2
Eddie18 - 1
claudio52 - 1
ARGOS - 2
CritterSoft - 1
rtan 1
Thank you for the recap. I think the time to wrap this up has finally arrived!
I've now made it possible to purchase the VFET chassis again, you can find it by clicking on the link in the first post or in the one above mine.
Please make sure you write in the notes your DiyAudio nickname so I know who has purchased the chassis
Estimated Delivery Time: before the end of November
I’m an impulsive hoarding flip/flopper…curse you Modushop! 🤪 Order placed.
Thanks, Gianluca. Have placed the order for the first of my three. It’s for a friend and going to his forwarder in Miami.
I’d like to ask your advice, Gianluca, and the advice of any Canadians on the thread with regard to the two other chassis. I have family in Canada coming to Barbados at Christmas and am going to ship my two chassis to them in Ontario.
Is it better to ship each of the two chassis separately - in terms of any possibility of coming in under a customs duty ceiling, or do I ship the two together at an obviously higher total cost on one invoice? The shipping charge difference between either option is €6.
I’m with you, brother. These chassis are unique and we’re not likely to raise 10+ again unless more Sony VFETs surface. Better to grab the opportunity while it’s available - are you listening, fencesitters (MEPER🙃)?I’m an impulsive hoarding flip/flopper…curse you Modushop! 🤪 Order placed.
Yes, yes.......listening!
I am looking at the speciel Mono block chassis with heat sinks on both sides! ......only way to dissipate the nearly 200W to use both sides for one channel.
But before I order I have to ask Gianluca to cut 4 x 10mm alu plates so I can connect the two heat sinks on both sides thermically as there is only one Mosfet or SIT pr. side. Hope this is possible?
You are very lucky with the VFET chassis that heat sinks are ONE piece only!!!
Are you sure the SITs can’t work on the VFET chassis? Seem to recall a post by ZM indicating you would be fine if you used a 60V power supply on the Tokins - or is my memory getting like ZM’s….Yes, yes.......listening!
Yes, close to 100W pr. heat sink in VFET chassis was a bit too much. It was the only reason I passed and looked at the standard mono blocks Modushops makes. They also have the nice baseplate with holes for mounting components. The only problem is the 2 heat sinks pr. side when you only have one transistor pr. side to dissipate a lot of heat and you need the cooling capacity of both sinks.
- VFET Chassis limited production run
