wim said:Are there better equivalent valves for this application? maybey the E188CC?
Is the ECC88 (no gold pins? not as good as the E88CC (gold pins) for this application?
I have a number of tubes i'm going to try, including cryoed 6N1P and 6H23Pi -- as well some exotic ECC88 equiv that starts with CV (IIRC -- came out of an AudioNote DAC). Also 6CG7 & 12BH7.
dave
yay! another dutch guy to build this little amp! 🙂
I don't know about your plans for this project, but I am going to do as much surplus as possible. Only the case will be new most probably...
Same to me, most of the stuff i bought already in the past year from Ebay, Marktplaats and Speurders. Only af ew things must be bought.
I hope the boards are coming soon!
digi01,
Did you get enough to include my 2 boards? Has not gotten an invoice from you yet?
Or did I missed this gp?
wim said:Hanzwillem, our boards are on there way! (see the WIKI).
I know! I started collecting parts. I just need to source LM3875TFs. I can order them at Farnell for 5.90 a piece through my university, but I rather order them myself somewhere...
... things are moving
I am sitting at my desk, the schematics nearly ready to post here.
In the meantime, I can show you two details about the d-sub connector, used for the power supply (NEVER connect some computer devices to it
1. Bridge between pin 1 and 3
You can recognize the yellow isolated wire between pin 1 and 3. The purpose of this bridge, is to activate the switch on delay. The NE555 timer and the relay are not grounded, as long as no plug with this bridge is connected. As soon as you connect the plug, the delay count 20 to 30 seconds before delivering power for the LM3875's. Disconnecting the plug immediately switches of the power stage of the amp. Just for the sake of your speakers.
2. How to connect thick cables to 9 pin D-sub
I inserted a thin piece of wire at the end of the thicker litz-wire and soldered it. Attach a piece of shrinking tube and you can solder it to the very small pins safely.
Next postings: the psu-schematic. Followed by a exact grounding and 9pin scheme within the next days.
Have fun!
Franz
dont forget: lethal voltages in this project!
Have fun!
Franz
Today i received the boards. They look great! Thanks. Only the building instructions are missing, Is that comming up on this forum?
Now i need the time to build the amp.
Hanzwillem, did you receive your boards too?
wim said:Today i received the boards. They look great! Thanks. Only the building instructions are missing, Is that comming up on this forum?
Nope, maybe they're at my parents, I forgot where I had them sent. Anyways, the mailmen in downtown Enschede are always very slow. I just have to have more patience...
The subject with the D-sub 9-p plug is not very clear to me; where to plug in this plug?
Is an updated PSU schematic coming up? Ans when do you aspect the grounding schematic?
Thanks.
Thanks.
Hi wim,the instructions will coming up on the forum.any problems during assembly please post here
Zang
Completely off topic Hanzwillem, but I have bought clogs in your hometown at the saturday markets🙂
Luke said:Completely off topic Hanzwillem, but I have bought clogs in your hometown at the saturday markets🙂
Did you now? 🙂
what brought you to my sweet little city?
- Group Buys
- VBITNGC group buy
