Nice work with the subwoofer integration with the OB. Your system design evolution has been fun to follow.I indeed can't locate the sub. It's push push slot loaded. And with some delay on DSP to time align everything.
I like the way the IB hides away and the OB isnt too big.
I very often listen to music/concerts on YouTube
Youtube concerts are fun. If you ever post up a youtube recording of your system in action let me know please.
Foam block is a corner bass trap, readily available. A cube bass trap would be more aesthetic, but I couldn't find one that is dense enough.Hi,
How do you find the big foam block ? Original solution ! 30 hz miss you not ?
The garden behind the windows looks good to... very green.
IB sub is cut off at 27hz for excursion protection... But I think it goes flat down to that point. So I don't miss much.
Garden is mostly cypress, palms, bananas and starlicae. Thanks 😊
