Variac .
When is a Variac used as a useful tool ?
You can do lots of things with it, like: adjust the input line voltage of a circuit to spec;
bring up a circuit slowly to allow old capacitors to burn in; check for circuit stability
when powering up/down or with line sag/boost; test circuits that need lower input voltages
than the AC line, without a step down transformer.
