True.
Something like this would work as the current being drawn is well under an amp.
https://www.antekinc.com/50w-linear-power-supply/
Well I've found a way to eliminate the class D amp.
While looking for a better amp for a speaker I use at work I found these.
https://www.amazon.com/dp/B0CDWTL57H
Tried a pair bridged and they work great to drive the speaker.
I then thought why not use it to power the motors. The amps don't put out enough voltage to directly drive the motors, however a 120V to 60V transformer might work and if not a 120V to 40V transformer will.
I tried the toroidal transformer and it worked ok. I then tried it with 1/2 the primary connected to the outlet and it still worked ok. The heatsinks got rather warm so I might see if I have a transformer of the ratio I need and try it to be sure it's not the toroidal causing the heatsinks to heat up. If the heatsinks don't get warm then I'll be good. If they do get warm I'll need a larger heatsink for sure.
Bear in mind that power transformers are wound with just enough inductance to avoid saturation at the rated frequency and voltage. If you use them at 30Hz then they are only good for 30/60, half the voltage. A saturating transformer will draw a lot of waste current from the amplifier making it overheat, etc.
I suppose the toroidal transformer might be better far as that is concerned.
Now what I could try is to connect the output to 1/2 the primary (two 115V windings in series) and take the output from the whole secondary just to see if it works like that. I'll then have se sort of idea whether or not a 1:2 ratio will work.
Toroidal transformers have no "air gap" so they saturate hard and fast. There is a related "inrush" problem with toroids if the power switch happens near crossover because there is no previous opposing pulse to reduce the average DC. If you are running low frequencies, use as much winding as possible at a reduced voltage.
Another variable frequency power supply I built a few years back using a Bogen CHS-60A amplifier did not like a toroidal transformer so I used a regular 15V to 120V several amp transformer which seemed to work fine.
Once I get the real 2050 chips installed I will see what transformers I have laying around the house and try them. I wanted to try the amps driving the load directly, however the maximum output voltage wouldn't be enough.
Using the class D amp I put an ammeter in series with the motors and they draw 120mA at 40Vrms at 30Hz which is about 9.23mA per motor given I have 13 motors. The current being drawn by the DC supply is 360mA.
Far as the power supply goes I could use a 1A DC supply if I still use the class D amp.
So here's the results with the TDA2050 boards.
The small heatsinks get warm to the touch but not hot enough to burn me.
The setup.
Loaded with the motors.
No load.
Will also try it with the toroidal transformer.
The setup.
No load.
Found a transformer that seems to work fine.
The power supply is set to its maximum of 30Vdc for the following measurement with the load of the motors.
So I will need to up the B+ voltage to 35-40Vdc so that I can get 40Vrms out of the transformer.
The heatsinks heat up about as much as they did with the other transformer only they no longer heat up without any load connected.
I will see if I can find a larger heatsink so that I can mount both amps to it.
For the power supply I'll use this toroidal transformer.
A bridge rectifier and a 10,000uF 50V filter cap. Just checked and at the output voltage shown I'm only drawing 310mA from the DC supply. Given the voltage is higher than 24Vdc I'll need a 24V regulator for the meter LEDs and the 5 volt regulator for the function generator.
I could use this one if I keep the unloaded B+ below 40Vdc or if I use a zener in series with the input terminal.
https://www.mouser.com/ProductDetail/STMicroelectronics/L7824CV?qs=GQP/xgjKl96cWFC%2B68wxSg==
That said I do not like the function generator I used due to it having to be manually set each power up. So I will find another that can put out 30Hz and see what dc voltage it runs on before I get any regulators.
- Design & Build
- Electronic Design
- Variable frequency AC power supply design
