@grataku
Hi, V1.2 is valid. No other iterations since.
See post #3,273 for a contributed pcb approach. Naturally capacitors size & tube sockets are not much flexible for choice when going with a pcb.
First page PSU architecture is valid. Shunt reg is subjectively better but trickier to set and hotter than Maida.
Good luck with the Valve Itch and let us know your progress.
Hi Salas, what's tricky about the Shunt reg? I have the 2 Shunt reg kits but I was looking for the Maida reg and couldn't really find anything.
Woops Algar just posted the same thing!
The only place found is the ready made neurochrome board. That looks handy but $$.
Hi, the SSHV2 shunt reg needs to set its main CCS for each app, gets hotter i.e. needs bigger sink and air circulation.More space. Its Jfet Vref can drift if the ambient delta swings much. Also generally more difficult to troubleshoot if damaged having both a series CCS and a parallel voltage section. A "super reg" architecture as some old techs used to say. Subjectively its different than series regs, you may like it more or not. Many diyers like it.
The Maida is series type, it basically uses an LM317 and a Mosfet shield, has no CCS. Shunt discrete or series integrated you decide which way you wanna go.
The schematic used back then was from an Italian blogger's link long gone down. But I think todd's Maida is exactly the same: https://www.diyaudio.com/community/attachments/todds-maida-mosfet4-pdf.208001/Hi. The Maida HV Reg link is gone, anyone has the schematic for it?
SB
Pete Millett also made a Maida. Google it up. Neurochrome's should be the most sophisticated Maida. But hey, they all are Maida.
This looks like a nice phono. Have anyone tried to do this with AC heaters? Is it getting to noicy... And/or a tube rectifier cirquit with CLC smoothing? It would be able to even put it in before a voltage reg like the Maida.
AC heaters no, I don't remember a posted build as such. Tube rectified with passive pre-filter B+ is a possible option.
#3,273 has a BOM alsoThanks for the info. Is there a detailled BOM somewhere for the latest ver1.2?
SB
Maybe I should know this but does AC heater on normal, non DHT tubes, increase the noise?AC heaters no, I don't remember a posted build as such. Tube rectified with passive pre-filter B+ is a possible option.
So, we could use 220K for R6 to be in the 280-300V output, right?todd's Maida is exactly the same
Is it also good to have the the LM317 on the heatsink? To cite Millett:
This is not because it dissipates power - it only drops a small percentage of the voltage across the regulator - but to take advantage of its overtemperature shutdown feature. If the heatsink gets too hot, the LM317 will shut down.
Finally, what heatsink size are we talking here?
Sorry I don't remember much about Maida implementation details. I only used Maida a few times many years ago. Before 2010. But I do remember the voltage setting resistors for the LM317 getting hot.
For high gain circuits it usually doesMaybe I should know this but does AC heater on normal, non DHT tubes, increase the noise?
Good to know! For the input stage of my 300b I used DC heater by default. It's dc heater from now on.
Peppe, I looked at the neurochrome site Maida and I am going with approx the same size or maybe 1.25x that. I would definitely heatsink both active devices.So, we could use 220K for R6 to be in the 280-300V output, right?
Thanks. I will see if I am able to prototype a PCB with the simple Maida schematic posted above by Salas.
By the way, that RC between output and ground is for helping LM317's stability. A cheaper 47uF electrolytic capacitor alone could do that trick instead of the 0.47uF 630V Wima MKP and the 4.7 Ohm resistor to give it artificial ESR. Maybe the original link's guy didn't have a high voltage electrolytic handy. Or he wanted it to sound different (kinda speedier/cooler), who knows.
I like Pete Millet version of the MAIDA, too.
http://www.pmillett.com/HV_reg.html
Was comparing the parts, Pete uses 317HV type, and a different series mosfet part. The suppressor parts p6ke39a for the LM317 seem like a nice touch, too.
Seems to me the fqpf2n70 series device has better SOA that IRF840 and higher max Vds but higher RDS on. I am not smart enough to figure out what the actual RDS is for the device at its actual operating point and how that affects dissipation.
Ale Moglia recommends the STF3LN80K5 3ohm RDSon. He says that the lower input capacitance is better, even in a series reg. I have lots of these.
The concept is about cascoding a low voltage chip reg with a high voltage semiconductor. To shield the reg from HV. Performance could be enhanced or degraded a little but the concept should basically work with many MOSFET and LV chip regulator types.
- Analogue Source
- Valve Itch phono
