Valve Itch phono
Sounds better but still needs more gain, with step-up Jensen + Denon DL103R (R.I.P.) volume setting was half volume, now to start to listen music I have to set to half the volume attenuator & near full volume to have the same gain than Jensen+Denon DL103R (R.I.P.) of course full volume I have noise so not pleasant, with step-up listening setting was half volumen.
When working well and having 4.5mV output given the phono is alright as before and will measure 40dB gain or more without SUT there is no reason to have low volume other than some wiring mistake. Check the wire pins colors on the back of the cartridge also.
