uStack Desktop Amp.
Hello,
I'm looking to build a desktop practice amp, no bigger than a sheet of A4 (not set in stone on size).
The idea being to create a little practice amp which runs off a battery (pp3) or maybe a wall wart. I have a couple of speakers to use and am thinking of making a very simple amp. The question I have is Class A or Class AB?
I was thinking about a simple single transistor Class A setup with volume and no tone stack(use guitar for that).
Then thought about building a Class AB just for fun. Not really huge power just want to get a decent little amp for practicing on.
Both have same (approx) amount of comps, so any thoughts?
Many thanks.
The words Class A and PP3 don't really go together 😀 The battery life would be measured in literaly seconds as it couldn't supply the current.
Best bet is a simple single rail chip based amp and suitable wall wart PSU.
One of the versions for practice guitar amp using LM386 that has had a lot of successful DIY builds is the Ruby Amp by ROG. It uses a simple JFet as a buffer between the guitar and chip amp. That will increase the input impedance of your practice amp, giving better performance. It will also warm up the sound a bit compared to going in direct. Lots of sound demos available, and it is only a few more components so it is easy to give a try.
Have fun!
