I have a pair of the PT5010 that I am keeping for a project that takes some inspiration from the LXmini. It will use the PT5010 mid and PT2522 tweeter above an up-firing small driver. The radiation pattern will be omni at LF and then transition to dipole around 600Hz or so. I might even borrow the "tube" idea from the LXmini, since it is a good one, but will use a different driver. The result will be a narrow and tall speaker with a small footprint. I have always wanted to try that, but it's just down on my list at the moment because I am working on other projects right now.
Ok, thank you!
I have the perfect woofer for a tall and narrow speaker, should I'd like to try... the 5x8 SBA racetrack woofer is very good.
Sorry to revive an old thread (there's not much else out there on this planar), and also sorry if this was covered and I missed it, but, why not use this driver as a tweeter also?
Further, I only listen at 75db, with some parametric EQ settings to dull the peaks down to 80db @ 1w, wouldn't this lower the bottom end?
I was thinking about putting an array of four of these naked directly in front of a GR-Research Triplethreat servo sub with a crossover at 120-200hz, my crossover software computer can delay the planars to time align the two, and presto, 20-20k two way...
