...Ground current could be directed along the screen if needed or it can be single end connected as screen only. The amplifier sees the voltage difference at the receive end of the Flow and Return pair. I don't think that can be said for a Coax, which must have the screen connected at both ends.
I think DF96 has a point. Shield (screen) does get connected to return path at receiving end in both cases, either twisted or coaxial. In twisted pair case, if the shield is only connected to return conductor at transmitting end, it still indirectly gets connected via return path at receiving end.
I suspect this practice of connecting shield only at one end came from ground loop problems that themselves came from confusion of signal ground (return) and chassis ground.
yes indeed , that is a big problem with single ended connections between boxes on different AC circuits, SMPS, class D, and/or digital noise. There is no common mode rejection, so any electrical potential difference in "grounds" can be impinged on a low level signal. ( ie hum or low signal to noise ratio S/N,). In audio and instrumentation, the Pro's go with differential signals, In audio choice goes to XLR plugs and jacks.
I need a new interconnect for my TT.
The best I have used so far was VDH coax but now, short of money, I am planning to build a new set of cables.
After readind about the pros and cons of coax and twisted pair, I am wondering if it is a good idea to twist two coax cables, use the inner wires for signal and return and connect both shields only on the input side.
This way, both signal and return wires will have it's shield and they will be twisted.
Please let me know your opinions.
You will lose most of the benefit of twisting, as the two inners will be spaced apart. About the only benefit of your idea is that the capacitance will be half that of a single coax - but that is not normally an issue with a TT interconnect, as sometimes extra capacitance is needed.
Twisted pair within a single shield may be better.
Well, I am using singularly thin coax so the inners will be suitably spaced apart.
But you did not tell me that I would experience some kind of downfall, so I believe I will loose nothing by doing it this way.
You might not get much interference rejection; that is what you will lose. Simple coax would be better. Shielded twisted pair better still.
Your idea would work in a situation where low capacitance was the aim, and interference was not an issue. Pickup catridges are not this situation, so you are solving the wrong problem.
Well, what I need is a cable that does not pick up interference.
The VDH I use, can be left connected only to the riaa amp (not connected to the cart) and there is no hum pick up.... other cables just act like antenas and the hum only goes away when I connect the cart closing the loop.
RC
I have made some Audioquest type DBS style 36 and 72 volt interconnects with and without single ended shields, and overall the shielded single ended for phono was the quietest way on my system.
Not much noticable noise or hum either way between pre and power connections with the same cables.
David
David
If connecting a cartridge to a cable reduces hum picked up by the cable then your problem is capacitive coupling of hum probably caused by inadequate or missing shielding/screening. Nothing to do with antennas - hum and RF are different problems.RCruz said:The VDH I use, can be left connected only to the riaa amp (not connected to the cart) and there is no hum pick up.... other cables just act like antenas and the hum only goes away when I connect the cart closing the loop.
So what I need is to try to eliminate capacitive coupling of hum using shielded cable..... my build does it very well, already tried it with good results between the TT cart and the riaa amp..... now about it's subjective sound is another story.... it just does not present highs the way the VDH cables do.
A TT cable basically has screening (to keep electric fields out), magnetic balance (either coax or twisting - to keep magnetic fields out) and capacitance (which may affect HF balance in a cartridge-dependent way).
Assuming no hum loops, the receiving end sees the difference between signal and return for both cases. The twisted pair is still subject to magnetic fields, and relies on cancellation - the screen is likely to be too thin to stop an audio frequency magnetic field. The twisted pair relies on twisting, the coax relies on cylindrical symmetry. There is a small advantage to the twisted pair if the screen is poor - you can still get cancellation if you have a differential input, even if an external electric field induces a signal. This may mean that a cheap twisted pair is better than a cheap coax.
Is there many quality difference between Amphenol, Canare, Neutrik or BNC's from other manufactures?
What are the criteria for verifying XLR connector’s quality? Do Amphenol and Neutrik meet the criteria?
Suppose two different arrangements for balanced differential connections: 1 - four BNC 75 connectors with four coaxial cables; or, 2 - two twisted pair shielded cables with two XLR connectors.
Are they equivalent? Is the first arrangement acceptable?
Connectors from reputable manufacturers will be the correct dimensions and will mate with those from other reputable manufacturers. Dodgy ones may not.
I don't know what you mean by a balanced differential connection if it needs so many connectors. One XLR (balanced) or one BNC (unbalanced) per audio channel is all that is needed.
Generally the whole point of balanced (or differential) is to have a twisted pair carrying the two signals in very close electrical proximity. The point being to limit the effect of any ground noise/bounce on the signal.
"balanced" in your context means, balanced impedance connection.
It's the impedances that must be balanced.
The two wire connection is simply that, the wires connect the balanced impedance output to the balanced impedance input.
On it's route the two wire connection must pick up least interference. This is where Marce's
become VERY important.a twisted pair carrying the two signals in very close electrical proximity
You can use two coax's as a balanced interconnect.Suppose two different arrangements for balanced differential connections: 1 - four BNC 75 connectors with four coaxial cables; or, 2 - two twisted pair shielded cables with two XLR connectors.
From Henry W. Ott
Just a general note:
Except that the physical paring can never be exact. It is impossible. It's the creation of a serious and audible problem, to deal with a problem that almost never occurs in the world of home audio.
So you end up with transient function issues. An Exacerbation, a false emphasis, an inserted and injected grunge in micro transient function.
Which people, or more tellingly, the human hearing mechanism can and generally does mistake for detail information.
Twisted pair balanced signal transfer, in home audio, or anywhere else, for that matter, is totally off the rails. It has no place.
It was the wrong hammer for an incorrectly conceived problem, in the first place.
It's well past time to see it for what it is, and just drop it ...and walk away.
IOW, "I don't sell that." 😀
- Analog Line Level
- Using digital interconnect as analog interconnect
