Good afternoon!
Finished the audio ADC on CS5381.
Connection interface: USB only.
The input buffer is made on an FDA op amp, so you can connect both balanced and non-balanced sources. Recording formats: 24-bit 44.1 kHz-192 kHz.
Powered by USB, current consumption 750 mA.
A pair of images: a noise shelf and THD, the source of the Victor generator at 1 kHz. The input divider -12 dB.
There are certain problems due to the low input resistance, so it may be necessary to recalculate the filter, which may cause a slight deterioration in THD
Not bad. I could buy it if I haven't had Asus Xonar Essence STX.
maxssau's device looks better.
Yes, it does.maxssau's device looks better.
Will there be boards available? This looks quite interesting for measurement usage.
Yes of course, contact me by mail 9890175@mail.ru
- Design & Build
- Equipment & Tools
- USB ADC on Cirrus Logic CS5381
