Hello all!
I have one week to finish my graduation project but there is a problem; shoot through
so i need a dead time circuit to overcome that effect
Please do not offer an external series gate resistor shunted by a reverse biased because of bad rise and fall times of output signal
Thanks in advance!
Thanks in advance!
Dead time
We designed a class D amplifier using discrete drivers for Nakamichi.
Your triangle wave signal drive line is the only place that you can place it
basically you run a comparator with a + and - theshold and only when the threshhold is exceeded can the output fets conduct.
The circuit is on an old MSdos printout so I need a fax to send to you
Stephen Mantz
Zed Audio Corporation
www.zedaudio.com
Stephen Mantz
www.zedaudio.com
try the voltage bias for comparators to unbalance them, though res+diode not so bad idea too (just 3% more loses, or so)
I once did within an old design of mine what Stepen is talking of. I once posted it on this forum. Maybe I can find it again. It was a complementary design so you'd have to watch out for the comparator input polarities.
Charles
Charles
Perhaps this can help: increase the rising time of the mosfets but leaving the turn off as fast as possible:
Instead of putting a resistor in series with each gate, put it connected to the NPN driver transistor. This way, when it activates, it passes current to the gate with the resistor in series (turn on), but when the PNP driver activates, it removes charge from the gate with no resistor in series.
Hope this helps.
Hope this helps.
search forum i good: http://www.diyaudio.com/forums/showthread.php?postid=429747#post429747
Here comparator drives drivers. drigvers trigger level for on/off and delayed on can bee made, it also makes it easier to make it self osscilating. In the tread the driver trigger level is also dealt with. Graduate ?
- Class D
- URGENT! Dead Time Needed for Discrete Gate Driver
