Updated Pass A40 Design
I completed a layout yesterday and pulled the trigger at PCBWay. The board will handle 3 X TO-247 Darlington or 2 X TO-247 mosfet/side. It is currently sized to fit between the flanges of my Conrad heat sinks. If the design works out as expected, I'll consider a more universal layout per the templates provided. Right now, the layout is for the enhanced circuit version with current mirror loaded diff input and Darlington VAS. I am using Toshiba TTA004B and TTC004B for the VAS stage to handle the extra dissipation.
Gottem boards.... I will likely start with the Darlington output version of the design using 3X each side TIP142G and TIP147G from onsemi. There are a couple of minor board issues that can be fixed with creative jumpering. First thing I will do when I get home will be to drop a board between the flanges of my Conrad heat sink to check fit.
Ed - Also ordered some 2N5401/5551 via E-pay for the low power transistors on this build. VAS will be TTA004B and TTC004B as previously mentioned.
Reactions: von Ah
Figured I'd put this here, as it is about an Updated A40. Recently finished this update with the help of WhiteDragon. With a slight modification to the input scheme, and 2 pair of MJH6284/87 darlingtons, I'm able to run it at 2A with 30V rails. Of course the sinks are lukewarm at best. With an eye towards a 3A bias, I'd like to add another pair of outputs, and keep those TO-247's safe. Is it as simple as adding another pair and maybe increasing the Re to say 0.75R? Are there any other values that may need adjustment? As it is, I dare say it may be better than my first A40 clone.
thanks,
John
The board was made to fit between the flanges of a double-flange Conrad cast heat sink, with the output Darlingtons standing up. However, it would probably work with the devices lying down on a wider heat sink. I only had 5 boards made. What I need to do to proceed is to figure out how to drill the flanges to fit the TO-247 Darlington packages. Until I figure that out, the project is pretty much stalled. No Gerbers will be made available.
thanks,
John
Sorry John
For not replying and updating your request for 6 output devices
To match the thermal stability goals of the original design
for Class A bias is closer to 1 ohm for 6 output transistors.
For Class A/B .82 ohm even .68 would be ok
Original design is using .68 ohm per transistor
Parallel degen is .68 divide by 2 = .34 ohms
For 3 pairs
1 ohm divide by 3 = .33 ohms
To drive 6 output devices would simply increase
the durability of the second gain stage driving them
and likewise transistor used to apply constant current
T4 and T5 have been changed from T0-92 devices to
more thermal Friendly T0-126 package.
Degen resistor slightly lowered to increase current
for the constant current source simply 100R 5%
lowered to 91R 1% to slightly raise current.
options included in notes to adjust idle with set resistors
and option to improve DC offset on output.
Original design approx 8 to 10 mV on output
Can be improved with one resistor change to be
around 3 mV to under 1 mV
of course click to enlarge
Reactions: gaborbela
