UPdate my alpine changer cha-634
HI
I updated my changer 😉
CHIP:
DAC: 192KHZ ---64X --- WM7816
OPAMP: 55MHZ ----LME49720
CAP:
1- ELNA Silmic II 6 pic (filter DAC)
2- WIMA MKP 1 pic (by pass Op amp)
3- WIMA MKS 1 pic (AVcc)
4- SANYO OSCON 1 pic (DVcc)
5- NICHICON 1 pic (Avcc)
6- Panasonic FM 2 pic (filter opamp)
7- ceramic COG 1 pic (by pass Op amp)
If you have any idea please help me 🙂
thanks .
afshin
hi
After various tests Avp op Amp to (I/v) after dac...
I came to the conclusion that opa2604 is the best selection for this point.
Distance and silence the noise components and shows dark and deep ...
627 At this point the little voice was cold and dull but for the output stage is good.
tanks.
Do you have an idea what pin of the D/A chip can be used to make optical connector out?
I want to connect this to the alpine pxa H701 that has optical in...
Volume control will be done with the pxa H701 sound procesor, this will be done through Ai-net canbus system. So its software controlled from the headunit volume controll button.
Wanted to try to scope, but now I got this error1 message..
It keeps on ejecting the cd magazine.....
I thought lets keep the printboard hanging loose, but later on I saw the shift pottential sensor. So I placed everything back as it should, but still error 1, Not sure what to do....
hi
I think you loss time control of magazine !!!
when I open main board I suction solder of volume control of time mechanism and not open 2 screw on volume time control ...
if you open 2 Screw on volume ( liner) on mechanism ... adjustment very hard and Sensitive...
thanks
