Uniform Directivity - How important is it?
From what I recall, the SEOS has less collapsing directivity--it has wider dispersion higher up?
If so, then the cornerhorn ... may be an good application. 😉
Instead of gently collapsing directivity to match a regular boxed woofer high up, here I'd think you'd want the widest directivity that matches the wide woofer/wall system and the wide midhorn (augmented by the corner). Hmmmm ...
Both SEOS certainly are sweet looking, grrrrrrrow!
Jeff
SEOS 24 looks perfect for something like this
:spin:
Jeff
Do any of the larger SEOS waveguides mate to larger diameter compression drivers? How low can it ultimately go with constant directivity?
I remember the corner horn that was at the MWAF, the first or second one, many years ago. It was a 15 in a reflex box with a triangle spacer to nest it into the corner with a 10" and a horn on top??
Hi Rob, it has been a while, no doubt. I really liked that original Midwest Audiofest, put together by Mike Baker. I think many of us made some good friends there. I liked that show so much I borrowed the regional show concept for GPAF and LSAF in Tulsa and Dallas, respectively. Some years, I still give the same "Crossover Electronics 101" seminar I did at Baker's MAF too. Didn't do it this year, but we're planning to have seminars again next year.
I'm kind of surprised you aren't all over the constant directivity cornerhorn concept, to be honest. It made enough impression on our mutual friend Duke LeJeune that he makes a version of the constant directivity corner speaker himself, the Rhythm Prism. Some words from Duke after hearing the Pi constant directivity cornerhorn at that same MAF show:
I've always thought all of Duke's speakers sound great. He really has this waveguide loudspeaker paradigm down, in my opinion.
So anyway, I'd like to respond to your comments a little more candidly than I might others, 'cause you and I go way back. I've seen you around the same forums for at least a dozen years, so please forgive if I write with some familiarity. I'm gonna pretend we're sitting in that demo room back at MAF, and we're just chatting. And I guess others can see us talking, and join in if they want too.
I don't see any advantage over a conventional box system as far as control of room modes. There is no directivity control below the Schroeder frequency like in any other system. You are still going to have to address room modes from corner placement like any other system.
I agree, 100%. This design approach doesn't address room modes at all. You would mitigate those with multisubs, just like any other loudspeaker system. But you could implement a Welti multisub configuration just by putting two additional bass sound sources in the opposite two corners. Or you could do a Geddes multisub configuration, placing them somewhere else. Either way, the constant directivity cornerhorn configuration does nothing to address room modes.
- However -
It does prevent self-interference notches from nearest boundaries, because the sound source is essentially flush with the boundaries. The sound source is within 1/4λ well up into the midrange, so it prevents early reflections and eliminates the response anomalies from nearest boundaries. It does provide constant directivity from the Schroeder frequency upwards, and that's a pretty big deal.
We all know at low frequencies the radiation pattern for a system is for all intent and purposes omnidirectional.
Yes, and if you put it in a trihedral corner it becomes confined to this spherical section, giving 9dB DI over omnidirectional radiation. Whether in freespace, on a baffle or at the apex of a trihedral corner, radiation angle is constant at frequencies where the radiator is acoustically small, i.e. below ~500Hz for a 12" or 15" woofer.
So in my opinion, if the room has the right corners, this can be made useful.
That's my point if the walls and only the walls are controlling the directivity of the design at the lower frequencies then using that logic I can place any speaker in a corner and make the claim it is CD.
If the sound source is acoustically small and the distance to the apex of the corner is also acoustically small, then yes, the radiation angle is constant and it is set by the wall angle.
The biggest problem of taking "any old" speaker and putting it in a corner is that it probably is not going to be acoustically close to the corner except at bass frequencies, so midrange will suffer from early reflections and self-interference.
But you can design a speaker for that placement, and that's what I'm calling a constant directivity cornerhorn. When properly done, it does provide constant directivity. In a large room or outdoors, it remains constant through the entire audio band. In a small room, it obviously can only be constant above the Schroeder frequency, but as I said, I still find that to be immensely useful.
Let me try a reverse logic on you, and sorry if it sounds like a smart aleck, but I think it will illustrate the point pretty well. It is sort of a reversal of your last statement:
If a straight-walled horn flare and only the horn flare is controlling the directivity of a compression driver then using that logic I can place any compression driver on a straight-walled horn flare and make the claim it is CD.
As you can see, this is a true statement. So I think the arguments about how a constant directivity cornerhorn would act in an anechoic chamber are somewhat academic, because the loudspeaker isn't designed to be used in fresspace. As AudioLapDance said, that "breaks" the speaker. It would be like using a compression driver without the horn.
Of course, a constant directivity cornerhorn crossover is designed for this arrangement. It is designed with the understanding that there is DI from the corner, and there should be physical design aspects that keep things in phase and acoustically close, both to adjacent sound sources and to the apex of the corner.
To me, this design approach is not unlike soffit mounting of a baffled speaker. The benefits of a soffit mounted speaker where the baffle is flush with the wall are similar, in that there is no directivity shift from omni-to-halfspace, the so-called baffle step. One would want to design a soffit mounted speaker to take advantage of this fact too. But in the case of the constant directivity cornerhorn, we go one step better because we include not only the wall behind the speaker but what would have been the ipsilateral wall too. So this configuration removes reflections off either one.
There is only one disadvantage of the constant directivity cornerhorn configuration, and it is a biggie, to be honest. But it isn't an acoustic or even an academic disadvantage, it is purely one of convenience. Or rather of inconvenience. The problem is the configuration can only be employed in specific room layouts, and frankly, it is the rare room that has this advantage. So most people cannot make use of this configuration.
That's why I also adopted the DI-matched two-way, after seeing the JBL speakers made that way. Seemed like a very useful compromise to me. And this kind of brings me back to the subject of this thread, which is that even though a DI-matched two-way isn't constant directivity, it can be made to be pretty uniform. The beamwidth narrows as frequency rises to the crossover point, and then becomes constant. That's a pretty smooth sounding configuration to me. Especially when soffit mounted flush, or if stand mounted, done with flanking subs to smooth the self-interference notch from the nearest boundaries, like the wall behind the speakers.
The Pi mid-horn is loaded with a 10" Eminence driver which means it can probably provide CD coverage to considerably lower frequencies.
I'm pretty sure they were going to use the BMS coaxial driver crossed around 400hz going all the way up from a single point source. The BMS distributor said that wouldn't be a problem. I'd have to double check, but I think he said he's run that BMS even lower. Of course, it's a very expensive CD.
I agree with you Wayne. A contant or uniform polar response is what matters most. Whether it should be wide or narrow depends on the situation and goal. Most horns have a collapsing polar that becomes narrower and narrower. Not only is that a problem for listeners off-axis, but it will also colour the sound in the sweetspot if the room is not treated with broadband absorption.
The only speaker besides a corner loaded horn that I know of that has a uniform response over a wide frequency area is Don Keele's CBT. Personally I leave omnis out, since I don't believe they work well in a bounded space.
Here's something I wrote in another thread about CBTs:
The CBTs can offer both; A spacious soundfield where the reflected energy resembles the direct signal and hence little coloration. Or a more precise and sharp image with treatment if that's what you want. The listener gets to choose and both will work extremely well.
A typical waveguide/horn speaker can however not give the spacious soundfield without much coloration. If you leave the sidewalls reflective, you end up with some reflective energy at certain frequencies and nothing or less at others. In that case, broadband treatment is required for accuracy.
With the CBT the floor reflection is a benefit. It is coupled to the floor and the reflection contributes what is effectively the other half of the CBT. So it negates the need for a full arc. This is a great advantage. It effectively eliminates the need for floor treatment that is problematic at best. Especially as any floor treatment typically exhibits a such a high frequency profile as to not be effective as broadband absorption for a traditional speaker. A bare broadband reflective floor surface is optimal.
The vertical disperion of a full CBT arc is 45 degrees. Therefore I am thinking that when placed on the floor, that the upward tilt would be restricted to 1/2 that. Thus from the horizontal plane it would only be a 22.5 degree upward distribution. As such, this effectively eliminates early ceiling reflections until well behind the typical listening position and thus eliminates the need for ceiling treatment, unlike typical loudspeakers.
The CBT benefits from a near uniform 180 degree power response and a constrained vertical distribution. In both axes it avoids a collapsing polar power response, which so typical of other designs.
http://www.xlrtechs.com/dbkeele.com/images/Card Back Large.png
And in all cases, the soundstage of the CBT offers an improvement over traditional speakers, as not only is the power response uniform over the horizontal plane, substantially increasing usable listening positions or eliminating many of the typical constraints that limit listening positons, and the limitations of a nearfield response due to destructive driver interaction (superposition) are effectively rendered moot.
I was thinking of the smaller SEOS with the woofer/wall and midhorn: so from 1.6k up.
But the big one is interesting ... pushed back into the corner, it would extend the horn, provide lower loading and decrease crossover. Do you think it could make it to 200Hz?
Wayne's philosophy is a bit different. He has 'first order' filters on the the woof and midhorn so they cross more slowly and provide two sources at 200 Hz to minimize the floor bounce notch in the ~200Hz area.
Jeff
What do you see is so rare about such a room...I mean, if you started with a blank wall and adjacent corners this seems possible to achieve.
WAF!!! 😉
No, nothing too spooky: They work best when set up on the short wall and crossed a bit in front of the listening position. Plus you need ideally ~6ft of uninterrupted wall (x, y, z). So not unique or anything but it is a bit of stacked criteria.
I have a room in mind ...
PS Wayne, where are those cool 'animated wave interaction' .gifs you posted at your place? (Less wave interference as you get closer to the corner) A pic is worth 1000 words ...
A resistive type enclosure with multiple 2" holes in the side walls and stuffed with denim insulation. The woofer used is an AE TD-15M.
That sounds quite ineteresting. I've worked with resistive vents in the past and would like to do so again sometime. I love my TD15M too, it's a great mid-woofer. Do you have pictures or a thread (here or AK - I believe you post there?) about this enclosure? I'm also quite fond of BMS drivers; been using 4550 on QSC waveguide over my TD15M for some time and am about to work with the tiny 4540ND on the small 6"x6" JBL PT.
IG
No, the controlled directivity is essential. But both waveguides in question have that, so there's no problem on that front. He's arguing that his waveguide has controlled directivity AND flatter response. His guide isn't as controlled at the bottom of the passband as the SEOS but that's the tradeoff he made for smoother response.
That's exactly right. The SEOS device produces some ripple, a result of its geometry. Here's some discussion about it, where Bill Waslo claims it to be audible, but suggests a way to correct for it in the crossover:
I personally think Bill's approach is appropriate for the SEOS - To do some sort of response shaping in the crossover to deal with that ripple. I think most people that design with those devices probably do something similar.
I just went about it a different way, making a waveguide that has inherently less ripple. It doesn't need notch filters.
We can discuss the merits of each approach. We can argue whether or not the crossover equalization approach is better, or whether it is better to do it acoustically with a different flare profile. We can talk about the optimizations and trade-offs, the secondary expansion to mitigate waistbanding, the depth and wall angle, etc. But we cannot even begin this discussion if we do not agree upon the data.
I think the two approaches are very similar, actually. Most speakers using SEOS horns are almost exactly like Pi Speakers, to be honest. I'm really glad to see all these new high-fidelity uniform-directivity waveguide speakers on the market. Fifteeen years ago, I felt isolated, surrounded by tractrix horn enthusiasts that saw constant directivity as nothing more than PA horns. Now days, the hifi scene has really embraced this paradigm, and it seems like all others are the outsiders. So I personally think that's excellent.
As an aside, Matt Grant is doing an exhaustive "Waveguide Shootout" right now. I think probably the SEOS/H290C comparison has been looked at pretty extensively, but some of the other popular devices haven't been. It will be interesting to see how they all stack up. I think the various approaches are all pretty well vetted out, like asymmerical versus axi-symmetrical, round/elliptical/rectangular, OS, PS, EC, conical or quadratic, amounts of secondary flare, etc. But Matt's measurements should prove very useful to show where each device is along this line of choices.
Wayne,
Have you been drinking?
My working assumption is that speakers with constant beamwidth always sound better than speakers that don't, provided everything else is equal.
A second assumption is that speakers with non-constant beamwidth but uniform-directivity - those having just gradual change - sound better than speakers with directivity that shifts radically somewhere in the passband. This is especially true if the directivity shift happens in the peak of the Fletcher-Munson curve where we are most sensitive.
When I say "directivity shift", I'm not talking about 20%, by the way. I'm talking about at least 50%. Beamwidth that stays constant within 20% is perfectly fine, certainly, at least for home theater or hifi. It's the shift from 90° to 180° in less than an octave that you'll hear, not the little bulge of 10° or 20° in a pattern that averages 80° or 90°. A 20% shift amounts to about 2dB at the very edge of the pattern, which is completely inaudible. But a 90° to 180° shift is 6dB at the edge of the pattern, which is most definitely audible. A shift like that screws up the spectral balance in the reverberent field.
So speakers with collapsing directivity (like DI-matched two-ways) can sound very nice provided the directivity change is smooth and gradual. The DI-matched two-way approach is a worthwhile compromise where constant directivity is impossible or impractical.
My third assumption has to do with the "provided everything else is equal" part. This assumption is where sound radiators are concerned, those with truer (flatter) amplitude response sound better than those with peaks and dips. This is true not only of direct radiators but also of horns.
What I'd like to see in this thread is a list of waveguides and corresponding response charts that are found to be smoother than constant-directivity horns.
This is what I was originally looking for, and also a discussion about the differences between systems with true constant directivity, say from 200Hz to 10kHz contrasted with those with collapsing directivity up to around 1kHz, e.g. the matched-directivity approach.
Waveguides offer the promise of smoother response than constant directivity horns, but at the expense of slightly less pattern control. For example, without a diffraction slot in the throat, they cannot maintain beamwidth in the top-octave, narrowing instead to the compression driver exit angle. They sometimes waistband a little at the bottom end of their range too, depending on the shape of the flare nearest the mouth. But in general, a waveguide provides constant directivity and also provides much smoother response than a constant directivity horn.
Waveguides are designed to provide smooth wavefront propogation. The wave, where it contacts the waveguide, is always perpendicular to the surface of the flare. This provides a nice, clean spherical section as the wavefront exits the mouth. It makes them act something like tractrix or LeCleach flares, but with nearly constant directivity. But different shapes and flare profiles offer different optimizations, and correspondingly different performance metrics. Some geometries provide smoother response than others.
An argument can be made that as long as response ripple is constant across all axes, then it can be equalized flat. The idea is that if directivity is constant, then the power response is the same shape as the on-axis response, so equalization in one plane is appropriate to all planes. I think there is merit in that argument, but I do not agree that just because a horn is equalized flat, it will sound as good.
There is a big difference between equalizing for mass-rolloff and using a series of tank circuits to tame response ripple. The conjugate filter for mass-rolloff is a simple single-pole high-pass, and is not a resonant condition. That is quite different than the conditions that cause ripple, and I have not found any cases where the underlying mechanisms that create this ripple come without additional penalty. Sound quality suffers.
You can always take a constant directivity horn and EQ out the ripple. We've seen several cases already in this thread of constant directivity horns with peaks and dips, the JBL 2370 and 2380 horns, for example. They not only exhibit mass-rolloff, but also have 5dB peaks in the passband. This can be equalized flat, but even so, those kinds of horns still sound harsh.
Consider that 5dB represents a 3x increase in power. Equalization requires a significant power shift - To remove a 5dB peak means the power is cut 3x at the peak, which also means that it must be raised in comparison by 3x everywhere else. This also means excursion is increased and everything else that goes with it. That is not the only issue, in fact, it may not even be the most significant issue. But whatever it is, there can be little doubt that a constant directivity horn is nowhere near as smooth sounding as a properly designed waveguide.
I have said many times before, I even prefer a good radial horn to many constant directivity horns, purely because of their sound quality. I can remember so many discussions over the years with tractrix horn guys, many that use a simple first-order capacitor and nothing else. They trade everything to get smooth response - out goes directivity, power response, excursion at the low end, etc. And when I say "out goes directivity" I don't just mean the horizontals, but even more so the verticals, because with a single cap, the forward lobe becomes a paper-thin strata. But still, they love the pure sound they get in that one pinpoint spot.
What I like about a good waveguide is we can achieve this kind of smoothness, and still provide nearly constant directivity. It really is a design approach that has one foot in the constant directivity world and the other in the audiophile response purity world. Of course, there is a continuum of optimizations one can choose, spanning between those two worlds. The waveguide can be more constant directivity or more smooth, or somewhere halfway in between.
Which brings me back to the suggestion that we make this thread list waveguides that provide response that is very smooth. I'd say a worthwhile criteria is no more than 3dB variance in an octave, i.e. +/-1.5dB. The bottom end can start anywhere from 1kHz to 2kHz or so, but above that point, we will ideally want response to be flat all the way to the top octave. Mass-rolloff is allowed, of course, but ripple in excess of 3dB is not.
What other waveguides are available that meet this criteria? There must be several examples of waveguides with exceptionally smooth response.
Speakers with uniform directivity sound more natural because the reverberent field has spectral balance.
If one could make a source that confined ALL the energy into the desired angular coverage, the reverberant and direct spectrum would be identical, this is the “grail” for dealing with room acoustics
Doesn't the reflection frequency response from room boundaries and furnishings also have a great deal to do with reverberant spectrum? Except for treatment of early reflections, are room treatment guidelines the basically the same for CD, DI, and speakers without directivity controls?
Thanks,
Darrell
Absolutely, I agree, 100%. But I think that if the speaker's directivity is peaky, then there's little you can do with the room to correct it. Except of course make the room completely absorbent, like outdoors. Then the directivity wouldn't really matter, at least in terms of spectral balance, since the direct sound would be all you heard. Directivity would still matter in terms of coverage though, of course.
The thing is though, rooms are never anechoic. I'm not sure that's even a desirable goal, except for making acoustic measurements. But I do agree that confining all energy into a desired angular coverage is the "grail" for dealing with room acoustics. That's why I like constant directivity cornerhorns - they do the magic trick of confining all energy into a desired angular coverage, bounded by the adjacent walls. They also prevent self-interference from reflections off the nearest walls, because the sound source is flush with them.
I also think that the DI-matched two-way is a useful compromise, which is probably why it has remained so popular for so long. Altec and JBL had been loosely using that approach for many years before JBL optimized the paradigm in the 4430 model in the early 1980s. That's when I learned about it, and began to adopt it for some of my loudspeakers. It isn't constant directivity, but it is smooth, something I would call uniform directivity. I think it gives a natural sounding pattern that's useful for most rooms.
