good day guys, I'm planning on building this amplifier, one thing that bothers me is how to make the inductor coils. you see, I don't have an inductance meter, can anyone help me on this, i'd also like to know if I'd be able to use my toroidal core ? thanks mates
EDIT: sorry, the pics are soo big, heheh my bad
cool pictures . about inductance try to use mini ring mini Ring Core Calculator it has most major cores but not all . i hope it will be of help to you . it is a very useful tool
if anyone has a link to a better program pls do post it's link.
Mini Ring Core Calculator Software Informer: Screenshots
looks like material 2.thanks stewin!
is the core T106-15? I'm just guessing
Here is a simple web tool if all you need to know is the turns required for a specified inductance....
Toroid Winding Calculator ? 66pacific.com
The use of both N and P MOS FET allows here the simplification of the gate driver using capacitive coupling.hi all just found this schema by detex audio . it seems simple . what makes it 100watts and not 200 watts?
But the use of this topology for bridged amp is less obvious.
Still, it seems to be UCD.
erorr in my mind
i creat this but it have dc on exit
why?
these boards are diferent!!!!!!!
which one is correct?
Hihi all just found this schema by detex audio . it seems simple . what makes it 100watts and not 200 watts?
why?
inductane meter for all have fun guys
http://www.diyaudio.com/forums/clas...00-watts-using-2-mosfets-274.html#post3216985
Hi
why?
no one answer????
stewin!!!!
no one answer????
stewin!!!!
i have not built this amp but the below link in post #139 i have tried and tested it
http://www.diyaudio.com/forums/class-d/205654-ultra-simple-class-d-14.html#post3091551
thanks to stewin
it is diferent with post #139
in this shematics and pcb the zener diods is diferent side
what?
which side is correct stewin?
can i use class d amp for HPF band like 6975 pioneer or tiuter?
thanks
what about the protection DC and OCP?
can you please send to me pcb files?
i am using protel dxp.
do you have it?
mr cpx try to hellp me but i can not do that beacuse i can not to find component and i dont have good knowlage.
thanks to cpx hellp.
thanks to you mr stewin.
what?
thanks
do you have it?
thanks to stewin
hi stewin
i need OCP exactly for any amp i creat
how can i creat OCP for post #139 amp?
the one on post #139 works perfectly i personally test it just use it exactly the way it is.
it does not include ocp protection .
hi stewin
Hi.
I currently am building that amp too, and i've got two questions:
first, concerning the amp itself: is a T20-52 core suitable for this one as output filter?
I guess noot, but i am not sure ... or would a T34-26 be suitable?
second, will this amp interfere with a SMPS mounted in the same alu casing, running with 50kHz? there is about 25mm space between the amp and the SMPS.
thanks in advance
thanks in advance
Try these stores:
Toroids, Ferrites, Parts, Kits, Toroid King, QRP Erector Set
2x Iron Powder Toroid Core T200-2, Iron Powder Toroid Core T157-6 items in urbasket eu store on eBay!
Iron powder cores, micrometals, T650-26, T300-26, T225-26B, T200-26B, T200-26, T157-26, T94-26, T50-26
All Iron Powder Cores
Materials 01,02,06 are suitable for class D.
- Class D
- Ultra Simple Class D
