Ultra-Low noise linear power supply 5VDC/0.7A
I think both me and Elvee mentioned this, to get the full benefit of the performance of the Denoisator/Nonoiser you shouldn't have these two stages close to each other. That means they won't be on the same board, hence why there isn't any final design that includes them. I can't guarantee the performance with AC to DC close to the regulator, hence I dropped that stage from my boards.
Average DIY-er might want to consider separating them if they want the full benefit of the very low noise supply.
This AC to DC stage might also be different for different use case scenarios. Since you can use a LM338 for higher output current you can imagine how different the AC to DC stage can be, between 100mA needed current and 4A for example.
I think it makes more sense to find/develop a rectification board(s) that fit the use case and use the Denoisator boards with those.
Reactions: YashN
Normally, the first post of a thread can be edited by his author; in this case, it will be yours truly, but all suggestions are welcome, especially yours since you have heavily contributed to the thread (moderators can of course also include additions, but they have many other tasks to complete, and if someone else can do it, that's the normal way to proceed).
An alternate solution would be the creation of a new thread, like "A denoiser's guide", but I fear it will end up as cluttered as the original thread.
The two solutions are not mutually exclusive, and you could perfectly open this "guide": you will be the owner and will be able to edit the opening post.
Personally, I am going to create the index in the first post of the denoiser thread, but feel free to create another, parallel thread (and YOU will have to manage it, obviously)
Sorry Bjornmagnus for the threadjacking, but it will be over soon, and in the meantime you have another possible solution to consider
I'll start looking through the thread as well and I'll send some posts that I think are of interest.
Hello Gerhard
greetings is it possible to post schematic of the
pcb in #10 i nee 5 volt 500ma
warm regards
Andrew
There probably are some boards left over, produced to fill space in a more important payload.
Cheers, Gerhard
Reactions: YashN
