Ultimate 4U 500mm Chassis - Who is interested?
Base Plate Option
  • Standard Aluminium 3mm or 4mm
    Votes: 5 23.8%
  • Aluminium + Custom Perforated Steel Base Plate 470mm to 480mm
    Votes: 16 76.2%
  • Total voters
    21
  • Poll closed .
Pico, this might be a silly question, but looking at the proximity of the bottom of the IEC mains connector cutout to the bottom of the base plate, which looks to be around 13.6mm scaling it off your back panel drawing - then when one mounts the inner baseplate inside the chassis, which effectively raises the internal floor height, will the bottom of the IEC connector clear the inner baseplate. I don't know how much height you lose when adding the inner baseplate - maybe Gianluca can answer that?
To give adequate clearance, do you think it might be wise to move the IEC inlet cutout up a bit and also maybe the speaker binding post holes as well. Just a thought.
The steel plate sits around 9.5mm above the bottom panel (ie on the one I have), so that would be a little greater than 5.0mm of clearance for an FKID IEC from the installed Steel Bottom Plate.
A non-filtered IEC would have more clearance again.
I could add an additional 10mm of clearance if that would make people feel less anxious
You better say now or forever hold your peace. Hahahaha
Based on your measurements then pico, I would be happy if you raised the IEC cutout and the speaker binding post holes by 10mm, for adequate clearance from these items to the inner base plate- what do other members think?
Certainly the IEC connector.
How far would that put the binding posts above the inner baseplate?
I am OK with that pico, as long as the bottom edge of the IEC connector comfortably clears the inner baseplate by 5mm or so that will be fine.
Do you know how the inner baseplate bolts to the chassis frame? Is there a fixed position for this?
