UL conversion
Thanks! I am also doing a hot rod of the internal amp of a Decca DP-11 portable turntable. I added a power transformer and an extra 35Z5 rectifier with two silicon diodes to form a hybrid bridge, which gets me to 188V B+ and adding an UL (40%) Edcor OT as well. Other than that it is the same. I noticed you used a 2.5K resistor on your screen so I guess that will work for me too. The 50L6 spec says it runs at 3.8W at 200V B+, so I'm hoping for 3.5W? There is no preamp but the cartridge runs very hot so no need. The original used a 150 Ohm Cathode resistor, I noticed you used 180 Ohm on yours. Should I change that as well? The motor runs directly off the line but my transformer puts out 140V so I need a resistor to drop 20V for the motor too right? Ill have to see what kind of current it is pulling at 120V to find that value.
