UGS adventures
pot on input
My UGS is standing in as a replacement of a P1.7 clone. I kept all the
metalwork, input switching and volume control stuff. So I have my pot on
the output side and it works like a charm. The advantage of the pot on the
output is that it is attenuating noise as much as signal. THe disdvantage
(to some attenuation methods, specifically a pot) is that the output
impedance of the amp changes with the volume setting.
I think the UGS has plenty of cojones and doesn't seem to have any issue
at all with output impedance in my setup.
Boy it sounds good.
because output impedance of attenuator itself will define output impedance of entire combo ;
I presume that you have some interconnects right after attenuator ?
Yes, there are interconnects. They have small capacitive and inductive
reactances, the input at the far end is nearly purely resistive impedance, and
the frequencies we're talking about are very low. These interconnects are
XLRs and they are well shielded and the shield is grounded. The result is that
there is basically no distortion or noise from the interconnect. My thinking is
that the distortion and noise of the preamp is higher. But I haven't
calculated it.
Have you done such calcs to come up with your conclusion? I wouldn't mind
seeing a proper analysis that says go one way or the other. It would mean
some rewiring in my amp but it's possible. Everything is modular - the
switching, volume, amp, PSU are all separate.
.....Have you done such calcs to come up with your conclusion? ........
nope , I didn't ; there is no need for that
I grew up hangin' around pro equipment ...... and - this is the way to do it , considering impedances , traces etc .
it's usually best way considering sound too , but that only your ears can decide
don't let anyone else to do listening instead of you :clown:
Finally, after some four years, I stuff my ugs boards :spin:
I spiced it, and played around a bit. Did anyone try to hold the fets on constant current by the use of bjt of opposite polarity clamped around it?
My sim shows a decrease in distortion roughly by ten times!
Rüdiger
Here you are with the relevant part...
Rüdiger
