UDNeSS, or You don't need Semisouth's
UDNeSS is about using active devices. So no need to use 2SK170s.
2x 2SK209GR will replace 1x 2SK170BL adequately.
50W rms into 8R means +/-32V rails and 1.8A bias.
You will need a total of 4 matched MOSFETs, each dissipating 29W.
This is just simuilation.
So build at own risk.
Patrick
Thanks Patrick. I thought about using the Toshiba parts because I have them. However, I did secure a small stash of the 2SK209GR devices due to you highlighting them.
I will try and play with the sim.
Mogens
Patrick
Do the upper and lower mosfets need to be matched together?
Or matching is needed only for the upper and lower pairs? Meaning 2 pairs and not a matched quartet?
Question on the OPA 604 opamp: it is still active, but not a single supplier has any stock, so it has basically become unobtainium. I checked the TI website, and they have many other audio opamps, but almost all of them can only have +/- 18 V supply. Would it be OK to feed them from a secondary supply with a L7818 3-point stabilizer connected to the 24 V rail? Would involve making a seperate PCB for the servo..
