ucd2k overheating
Ok.
First of all, the drawing in the datasheet is wrong 😀 It aint a 10mm hight
difference to the cooling element. It looks more like 1mm.
The amp has been running in idle for 15minutes and I can hold my fingertip
on the side of the coil for at least 10seconds, a fair estimate would be that it's
at 45-50degres C.
As I remember it the cooler element would get extremly hot if not
attatched to an additional cooler and maybe what you are experiencing is
radiated heat from the cooler accumulating in the coils.
I will leave it running for an hour or so and get back then.
