UCD180 questions
Alright alright.... I see how it is.
All the same I stand by everything I said 100%, but I won't push the issue "too" far.
Yes the marketing thing seems dishonest to me but it is marketing and so typically walks that line. I'll say in interview they did a great job walking the line, in forum replies they did a horrible job laying blame.
That's why you're now seeing posts asking "how much power are they really good for" because he claimed a Hypex module + power supply will only get you 55W. I'm sorry, that doesn't sound like owning up to anything to me. However I'm not sure it was CIAudio's mistake either, other than not spotting it before review time.
I never said they didn't modify their module, I said modifying it does not constitute original design.
As per the reviewer...
Does it honestly seem to you, Mark, that I care about what's popular? lol.
First of all you just had a "golden ear" not tell the difference of having the equivalent of a few series light bulbs in a power supply, and the problem is that he in fact did compare such an amp to a well performing 3k$ one.
Maybe he cares about what' popular and was too afraid to say it didnt' sound so great.
A UcD180, which was under-performing, was competative with a $3750 amp!
You're actually ready to believe that?? :whazzat: Bring on the Shakti reviews.
It would be nice if some of the other folks--not you Yves!-- who enjoy trashing people from behind a keyboard had the bravery to pick up a phone and talk to them first....
You could have had the bravery yourself to add a name to that statement, but I assume you mean me so..
I wasn't replying to what was a private phone conversation, I was responding to what were public forum post replies (includes forums other than here, those which Hypex may not frequent), and public articles. I therefore fail to see why I should change the venue to a private one.
Anyway, that's all from me on this matter, I'll just go wait for the lawyers to start calling.
Anonymous
Hypex gets mentioned in the review so that's going to make OEM business for hypex for sure. I do hope Jan-Peter will keep support DIYers in the future, with good products at excellent prices...
YES! and when Jan-Peter and Bruno become wealthy, as the quality of UCD allows to think, they will continue to create gorgeous DIY products for us, humble amateurs, from his Bahamas' Island 😀 😀 😀
Mauricio
Isn't "wealthy" the finest sounding word in english language?😀
CIAudio has repeatedly stated that he sent it out with the current limiting wrongly set--it was not a Hypex issue.
I'm not the kind of guy that would think "Hey, one guy's amp is acting up, all the modules must be sh*t" - 'cause I have the modules, and they're doing exactly what they should.
I wonder... current limiting, changing that would require lots of mods on the module....
The Audiocircle articles mention that the current limiting was influenced by temperature.
Could it be that there was some kind of thermistor used as soft-start and it just kept limiting current?
It could explain the "bad comments" in the stereophile article, all that was commented on was bass (high energy) content that didn't sound right. I'm sure it wouldn't sound right when clipping, lol! 😀
If that was the issue, then no apparent flaws were found in the modules at all 😱 😀
Thanks for the link to Audiocircle where CIAudio takes the blame.
After reading about the UcD technology I was expecting great results and was therefore very disappointed by the first set of measurements. The second set however shows that UcD is the best class-D design out there.
As for comparing a CIAudio amp to one with a $3k pricetag, I think we all know that the price of a product is not determined by the skill of a companys engineering department but mostly by the skill of their marketing department.
And just for the record, I stopped reading the subjective part of stereophiles reviews a long time ago, only reason I still subscribe is because I might learn something from the measurement section. And the occasional audio pr0n pictures ofcourse 🙂
???????????, they even don't use an AES17 filter, as recommended by AP for measuring on Class-D amplifers.
A small part of Bruno communications with somebody else who tries to measure with the wrong filters on a Class-D amplifier.
I tried running graphs using the 30kHz post-notch filter, but at low signal levels and low distortion levels this doesn't work very well. The standard 22/30/80kHz filters are applied after the notch filter, and the level detection / autoranging circuit of the AP2 is therefore still seeing the signal with the full HF ripple on it. The reading A/D is left to detect THD using only the lowest few bits. This is not a problem when you're testing an amp with 0.02% THD, but the UcD400 puts out something like 0.003% THD at 1W and this is below the detector resolution of my SYS2322
The SOLUTION is to use the AES17 filters, what prefilter the high frequency ripple before it enters the measurements system of the AP.
Jan-Peter
Hi Ivan,
How did you like the changes the series load resistor made?
I thought of and tried this awhile back, but it was to lift the loads return line for better ground sensing, didn't find much difference.
Jan-Peter ty for pointing the inept measurements of the reviewers.
They should stick to the subjective aspect and not bother with measurements they don't know how to make.
Chris
I know, I know... As I said I can learn something new, including how NOT to do things. AFAIK Atkinson has never said how his 6th order filter is made.
I see now that you have updated the UcD180 datasheet with more info, much appreciated. The EMC measurement is very impressive especially compared to some other high-profile class-T manufacturer...
classd4sure said:
Seeing they are so different, the reviewer didn't even listen to the same amp; he should do the whole listening test again if he wishes to remain credible.
Definately.
Chris,
i don't like it, i suspect lower damping of the speaker do overall Qts higher, and produce several heterogeneitys on the frequency response around bassreflex resonance region + longer bass decay. How i can like it, if it's inherently aren't fidelity?
BTW, i was similarly disappointed by the my tube buffer, which do smoothness and roundness from the everything what's gone through it.. i can assume, that such enhancering could be sweet for someone, but not for me yet..to be honest, let's make enhancer by the DSP MIPS, please note -without replacing DSP core each 6-12 month unlike tubes.:whazzat:
Thanks alot Ivan for that excellent reply.
I didn't like the results I saw in simulation with it there at all either that's why I quickly removed it.
In my case the diffefferential feedback was meant to sense the ground itself and I found the resistor was basically impeding it from doing its job well, excuse any semblance to a pun there. The only reason it wasn't a mistake to try it is because obviously a lesson was learned on my part, and I see on yours as well. You're saying the D-X00's use that? I wonder what they liked about it.
You haven't really specified if what you tried or they use is placed on the high or low side of the load though, either is still in series but would make a big difference. I'll assume it's all on the low side.
I also agree with the tube thing, seems to me it's an accepted fact that tubes color the sound, if you like it OK great, if not well you're stuck because it's an effect that you can't disable, limiting your "audience" to the few, which yes does indeed lead us to a DSP. I played around with mine and don't like it at all really, it always sounds best when disabled. I'm sure for some people they have their uses. The noise and test signal generators are fun though... all _three_ of them.
I think the fact you went at the tube project and pulled it off is excellent work and a great DIY example. It was very interesting to read about too.
Just think, if you weren't so honest, marketed it as the only UcD that is worth listening to ...... sold them for 50K USD each... well you'd be rich, probably have some good reviews too.
Why not wait for the UcD700 and we'll do a hot swap discrete input stage for a 100K/ each group buy, featuring a discrete class A, Jfet, and tube input stage.
We can jack our profit margin sky high because now we know we only need a fifth of the rated power before clipping out of it and still get wicked reviews :angel: That should even allow us to use an all monoblock design based on a series lithium cells, just imagine the write up!
Hm, I need a hobby.
quote:
Definately.
Definately.
Hi there,
While I'm not offended or anything, that's Yves you're quoting there not me.
Unless, you're messing with me? ...knowing full well I'd respond with "what do you mean by "regain" credibility, that implies...heh....naaaaaaaaah".
Cheers
Worthwhile goal
Yves Smolders said:
Max,
Shiny books with raving reviews *DO* help when you want to push some "friends" to... donate, so I can build them fine-sounding amps - donate enough so I can make the amp and have a nice dinner or maybe even a city trip with my gf 😀
Yes, a worthwhile goal! We all need to have a life outside of this stuff, unlike some I could mention but won't.
Roger
