UCD180 questions
Bobo le Chat has a UGS, balanced preamp, and uses it on the UCD. He told me that's it's pretty nice !
Now, i am using them on the pre of my Yamaha 4600, awaiting the PCB of my UGS !!!!! I think after 2 weeks i will be able to feel the difference. Roger told me when we use the UCD on unbalanced there is a "lost" of 6 db. What about this...?🙄 I need to put the pot of my preamp little bit more up than before.....
Wait an see !😎
breizheau said:
Hi there,
i puggled my UCD on my balanced UGS preamp. Juste to remind, the UCD have straps, power supply and LM4562 mods. My godness !!!!!😱 What a sound !!!!!!!It's powerful, neat, clear, detailled. I enjoy them a lot !😉
Ah...you also like the LM4652! In the new UcD180HG we will also use this wonderfull nice op amp, together with a lot of 'other' improvements.... 😎
Jan-Peter
Jan-Peter [/B]
Hi !
I've read on another thread that without opamp there is 10 dB less gain. In my application I don't need much gain, is there some drawbacks to bypass the opamp. 😀
Maybe it is quite a stupid idea :smash:
I just need one or two watts at the output at full listening level so at the moment I use attenuators at the input of my amps for the midrange section :bawling:
regards
Marc
mbon said:
Hi !
regards
Marc
Is possible, but if you connect your source direct to the UcD Modulator you the big disadvantage is that the input impedance of the UcD Modulator is not symmetrical!
The HG version with the LM4562 sounds very neutral.... 😉
Jan-Peter
Jan-Peter
Thanks,
so let's say I will buy the new UCD180HG (in fact it is sure but when
:hot: :hot: :hot: ?)
is it still an (good ?) option to change Rg, let's say Rg=Rf to have low gain :
http://www.hypex.nl/docs/gainappnote.pdf
I mean is it better to change Rg or to add another attenuation circuit on the input ?
many thanks for your help. I am refreshing the home page hypex.nl every day looking at the 180HG 🙂
GAIN
HELP!
I am a remedial
I am considering hooking a pair of PGA2310's direct to the UCD180's input (bypassing the opamp) or maybee just one, my question is weather the gain will be suitable for the input, +31.5dB to –95.5dB, I really could do with knowing the input sensitivity of the modulator and what this means in terms of required input level (and how to calculate this) I dont even know the relationship between Db and RMS input.
Please help!
Hi
I´m new at this forum, but i find it very intresting here, and i can find ansvers on many issues.
Still I have a question
Can anyone tell me if i can use 24 + 24vac 300VA toroid to power up a ucd 180? It will give me about +-34vdc
Will it decrease the power, or increase the distortion.
Is there any one who knows?
Gustaf:xeye:
UcD 180
Gjander said:
Hi
Gustaf:xeye:
Dear Gustav
That's not a problem but take care about the electrolytics. They should handle over 40 Volts! Also have a look at www.hawkaudio.nl/d402.htm. The schematics are in the dowloadable building instructions. That amp has a 2 x 22 Volt supply and easily outputs 40 Watts into 8 Ohm and 70 Watts into 4 Ohm. It's in use by a lot of audio diy amateurs around the world and all are happy. If the connected loudspeaker has an efficiency over 87 dB/1 W/1 m then you might blow your windows!
John
UcD...HG
We're delivering the HG-version in our kits now. It's a major improvement. We already experienced that quality earlier when we used the same LM4562 in our modified models.
In our D-701-HG we also implanted shunt regulation for the power supply of the input circuit. That amplifier now equals (or even outperforms) almost any tube amp even SET ones.
Have a look at http://www.hawkaudio.com/D702.htm
