UCD 25 watts to 1200 watts using 2 mosfets
the project advances, already corrected some faults in the PCB, ready to do a few more, the small card is a modulator / demodulator with balanced input and output for LO and HI for the 4 mosfets, but the main card can be UCD, DELTA SIGMA auto oscillating, or double feedback, post filter and pre-filter feedback, basically universal, I will soon post the PCB and schematics only of the main board and the UCD and delta sigma versions.
The evolution
Advances in the project ........ 1,800 RMS .008 DHT + noise etc you would need to hear it, it is wonderful, only unipolar source from 40 VDC to 140 vdc
Hello to all! Sorry for my English. The problem of connecting several class D amplifiers (UcD) to a single power source is solved simply, it is necessary to power each amplifier plus power and minus power through separate diodes (for example, MBR30200CT). Thus, I connected four channels from one source and everything works fine. Sincerely, Boris B.
Im also trying to figure out whether I can connect two class D amps, TPA3255, to a single SMPS PSU.
Here is a picture of the MBR30200CT
So are both the + and - leads of each amp simply connected in series with such a diode (4 diodes total) and the connection is made between pins 1or3 and 2?
This would be enough to prevent any interaction making it through the filter caps of two unsynchronized switching amps, correct?
the lm311 post and pre feedback project is coming up......
any opinions and comments are appreciated.
project details in the below forum
Class D Amp with LM566, LM393 and 2XIRF530
Hi Stewin,
I have finished double feedback. Here my Schematic if you interested.
Basically this is standard IR based, but the key is use higher LPF cap 1uF instead of 680n or 470n to lower the ripple so that during start it will not take over switching oscillation (usually get 60-70kHz if oscillation failed).
Double feedback you need to be careful of fail start. It can damage your speaker. SO I add Fail Switching protection
This is firm design. PCB available in indonesia.
Have you considered synchronizing them (using the OSC_IOP and OSC_IOM pins)?
Hi Stewin,
Is it a pcb for sharing?
No, is it really as simple as connecting one or two wires between them?
Edit: found *Multi-Device Configuration for TPA32xx Amplifiers" with keywords from your reply. Thanks!
