I've never found specifications for the tantalum resistors; I thought they'd be tighter tolerance and better Tc.
In the objective sense, which is what I consider first, the Tycos are very good--better than any of the other parts mentioned except bulk foil, which are the very best of any resistor of its size and ratings.
Subjectively, some people prefer the sound of carbon resistors, which have poorer electrical specifications by a considerable margin. Carbon composition appear to be actively piezoelectric--very poor voltage coefficient--but again, some people prefer what they call a 'warm' and rich sound.
I actively search for bulk foil resistors but the best of that type, the Z-foils are outside my budget altogether--and I really don't like the construction of the 'naked' bulk foil types. So I can only use them very sparingly in what I think are the most critical locations, and use the best metal films in most other locations.
In non-audio applications, as long as tight values and low Tc aren't required, most any resistor type will work fine. Don't overlook wirewounds, some of them should be nearly as good as bulk foil if their Tc is very low. But they are not as common as they once were.
