Twisted Sounds 8.5k
Are the relays engaging/closing?
Do you see any DC voltage on the output filter inductors?
Is your scope set the AC coupling?
What make model scope?
Please (and this applies to anyone who needs repair help) use your sig line to list all equipment you have, editing it as equipment changes. Include the model numbers.
Oscilloscope (yes or no)
Multimeter(s)
Type of signal source (grounded RCA shields preferred).
Soldering iron
Desoldering pump
Power supply
2 ohm current limiting resistor (hollow cylindrical ceramic 100w preferred)
There is a 3ed inductor on the output side. Idk if that means anything.
I'm sorry, I misread. It generally is the secondary ground but there are exceptions. H-bridge output have output on both speaker terminals. A few amps (maybe a layout mistake) have the signal on the negative speaker terminal.
The DC is likely causing the amp to go into protect. The relay is likely closing and them immediately opening.
Is the protect LED lighting up?
