I read about current drive mode for audio amplifier to reduce distortion:
http://acousticsnew.ippt.gov.pl/index.php/aa/article/download/1780/pdf_255
Amplifier topologies for current-drive | Current-Drive - The Natural Way of Loudspeaker Operation
Clean-current speaker project | Current-Drive - The Natural Way of Loudspeaker Operation
Why current-drive? - An active current-drive audio systemAn active current-drive audio system
The serious flaws of voltage drive | Current-Drive - The Natural Way of Loudspeaker Operation
Current-Driving of Loudspeakers
Inspiration for future ZEN Versions - basic description of Italians 400.000 $ Amp
Current drive for Loudspeakers
https://www.edn.com/loudspeaker-operation-the-superiority-of-current-drive-over-voltage-drive/
http://www.ultrasound-hifi.com/Us_wh_1/FR/Amplificatori/amplificatori_en.html
http://www.ultrasound-hifi.com/Us_wh_1/FR/Amplificatori/pilot_corrente_en.html
But what about current drive mode for turntable synchronous motors ?
Are there audible advantages and threads about this and conversion procedures from voltage drive to current drive ?
Are there commercial available motor driver devices working in current drive mode ?
Thank you very much for an advice.
This commercial available motor driver devices, which I know, are all working in voltage drive mode:
Linn Axis PCB
Repairing Linn Axis Motor Drive Amplifier
Linn Axis Schematic
Music Hall Cruise Control 2.0
https://musichallaudio.com/product/cruise-control-2-0/
http://www.turntablepsu.com/music hall.html
H.A.T. CPS Powersupply for Thorens TD124
https://shop.hanzehifi.nl/product/h-a-t-cps-thorens-td124/
https://positive-feedback.com/reviews/hardware-reviews/the-hanze-hifi-hat-turntable-power-supply/2/
https://www.analog-forum.de/wbboard...-power-supply-on-positive-feedback-geschrieb/
Longdog Audio Motorsteuerung Synchronmotor u. a. Lenco Garrad-Thorens
https://www.longdogaudio.com/product/lda-quartz-turntable-power-supply-mkii/
https://theaudiophileman.com/quartz-turntable-supply-news-long-dog-audio/
Phoenix Engineering Falcon
https://www.theabsolutesound.com/articles/phoenix-engineering-eagle-psu-and-roadrunner-tachometer/
https://www.lpgear.com/product/FALCONTTPSU.html
http://www.turntablepsu.com/phoenix.html
https://www.analogplanet.com/content/phoenix-engineerings-falcon-psu-and-roadrunner-tachometer
https://www.audiocircle.com/index.php?topic=155478.0
https://forums.stevehoffman.tv/threads/phoenix-engineering-llc-closing.632336/
Pro-Ject SpeedBox SEII/II
https://www.project-audio.com/de/produkt/speed-box-s/
http://www.turntablepsu.com/pro-ject.html
Pink Triangle Too PSU
http://www.turntablepsu.com/PT.html
http://thefunkfirm.co.uk/shop/turntable-upgrades/lp12/
Rega Neo TT-PSU
http://www.rega.co.uk/neo-turntable-psu.html
http://www.turntablepsu.com/rega.html
VPI Analog Drive System
https://www.vpiindustries.com/ads
http://www.turntablepsu.com/vpi.html
https://forum.audiogon.com/discussions/vpi-analogue-drive-system
Walker Precision Motor Controller
https://elusivedisc.com/walker-audio-precision-motor-drive-speed-controller/
http://www.turntablepsu.com/walker.html
Dr. Fuss/Linn Lingo Drive System
https://www.diyaudio.com/forums/ana...it-description-sine-wave-osc.html#post5995157
http://www.frank-landmesser.de/hoer_analog_netzteil.html
Linn Lingo vs. Dr. Fuß or Square-Wave vs. Sine Wave Oscillator for Motor Control
Overview turntablepsu
http://www.turntablepsu.com/index.html
http://www.turntablepsu.com/technology.html
Various Threads
DIY AC motor control
Optimally driving a (VPI) synchronous turntable motor
How does turntable AC speed controller work?
Synchronous Motor Driver for Dual CS522 or CS505 using SM100-1 motor
Speed control for syncronous motor
Linn Lingo schematic
Linn Lingo Mk1 toggles continously between stall and normal mode
I want to hire someone to build an AC synchronous motor drive
Linn Axis PCB
Linn Axis Schematic
Rega Neo TT-PSU
Various Threads
What is it you are trying to accomplish? Lower distortion of the drive signal? What benefit do you perceive by doing so? According to Mark Kelly, a slight amount of anti-phase 3rd harmonic distortion is actually beneficial.
Is this 3rd harmonic "tuning" intended to compensate for to nonlinearity in the source, the load, or both?
Getting best possible sound quality at a power supply/motor control for Linn LP12 record player and similar models with same drive motor (as an alternative for Valhalla/Lingo).What is it you are trying to accomplish? Lower distortion of the drive signal? What benefit do you perceive by doing so? According to Mark Kelly, a slight amount of anti-phase 3rd harmonic distortion is actually beneficial.
If I knew what benefit I am perceive, I would not ask here (this is the intention to start this thread).
Check out
Maybe the isolation transformer between control circuit output and motor input from the Dr. Fuß power supply provide additional H3.
Maybe this transformer also create more current control character.
If I were able to make exact measurements of voltage, motor current flow and 1KHz spectrum with a test record like to find under
Linn LP Playing System Measurements | Stereophile.com
I could find out everything on my own.
A small amount of H3 was thought to reduce cogging in AC synch motors.
Interesting. Apparently everyone does this but I'm just now finding out. Fancy! Example:(PDF) Torque Ripple Reduction of Interior Permanent Magnet Synchronous Motor Using Harmonic Injected CurrentA small amount of H3 was thought to reduce cogging in AC synch motors.
Thank you. Is this PDF under
https://www.koreascience.or.kr/article/JAKO200934939515685.pdf
also available in Englisch ?
This PDF is available here, and should be in English:
Torque Ripple Reduction of Interior Permanent Magnet Synchronous Motor Using Harmonic Injected Current - IEEE Journals & Magazine
It's not free, it is $15 for IEEE members and $33 for non-members. Click on the red "PDF" button then click on the "Purchase" tab.
Ray K
Ray K
..... According to Mark Kelly, a slight amount of anti-phase 3rd harmonic distortion is actually beneficial.
I think Mark is on the right track. I’m an electrical engineer and before I retired I worked on projects with multi-thousand horsepower 3-phase synchronous motors. In this size range the rotors are built with wound coil poles and energized with DC current instead of using rotating permanent magnets. The rotor pole pieces are contoured and the stationary coils which are connected to 3-phase AC are overlapped so that the rotating magnetic field and the “pull” from each phase is as purely sinusoidal as possible. Because the 3 phases are 120 electrical degrees apart, the mechanical torque developed by each of the three phases ideally sums to a uniform cog-free torque on the shaft. If it’s not done right then you get vibration, and it puts harmonic distortion on the incoming AC power line.
It appears to me that “shaping” the magnetic field in small synchronous motors is physically difficult but pre-distorting the AC input voltage with engineered “anti-harmonics’’ to compensate for the inherent cogging would be effective, and that is what the research paper demonstrates. I have a feel for what they’re doing by looking at the figures and graphs (I can’t read Chinese), but the math is above my pay grade. It seems counter-intuitive, but the research suggests a power supply that generates a pure sine wave might not be the best approach.
Ray K
Nonlinearity in the load.
Ray K
- Analogue Source
- Turntable Synchronous Motor AC Speed Control Driver (PSU) in Current Drive Mode ?
