I've got a pair of Turbosound TS-8sw400A8 drivers from a defunct pair of Turbosound Inspire iP500 speakers.
Any idea what the specs are for the driver?
I looked online and could not find specs.
Audio Labs sells them, so best option AFAIK and being primarily a DIY oriented store (at least historically) may even measure one if they don't already have them: https://audiolabga.com/
Just emailed them.
I also asked them that if those woofers aren't good for my purpose do they have any that will work for what I need.
Of course I could always take one home and listen to it just to hear how it sounds.
They didn't have any specs on it.
Decided to bring home the six Turbosound TS-2FR80A6 drivers also used int hat speaker.
Here's the specs of all the drivers.
Woofer.
2" driver single.
2" drivers as originally wired.
I used this calculator https://www.bcae1.com/spboxnew2.htm and it said both the woofer and 2" drivers were better suited for ported enclosures.
Would open baffle be out of the question for these drivers?
Woofer.
2" driver single.
Bummer! They use to measure folk's driver purchases for free and a few $$ for your own. Oh well, times change and prosound drivers are normally only used in recommended cab designs nowadays.
Thanks! Can't have too many measured specs!
With specs basically for a max flat vented alignment it all depends on how high above an Fs roll-off you're willing to tolerate.
More than likely if I do use the drivers I'll use the 8" woofers as midbass drivers in a three way setup and not even use the small drivers.
Listening to the small drivers I suspect they applied some DSP to them as at a certain upper midrange frequency they don't sound all that good. So I doubt I'd use them unless I were to use 6 tweeters in a line array crossed over about 2.5kHz.
