all the fuse online are 250v can I use that?
that is the maximum voltage rating and they are good for use in this amp. Do not use 32 volt automotive fuses. I would use a 2 amp fuse. A 2.5 or maybe a 3 amp fuse if you can't find a 2 amp. Do not use a 10 amp fuse it will not save your amp from a meltown if anything goes wrong.
The kits were shipped out today since the post office was closed yesterday due to holliday.
Same here on my 6cw5 SPP.I think I have a 2A slo-blo in mine.
thank you, so i can order mine now all these shipping cost are killing my wallet $42 so far. I hope this amp sound awesome with alpair 7.
I have both - the source / program material may be the weakest link (for example you will hear MP3s for what they are)
George, good to see you're still givin 'er
Still here.....or there. Right now I am in rural West Virginia about 1200 miles from home. I haven't been to work in about 2 weeks, so I lost track of what day it was. I went to the post office to find no one home....Doh Monday was a holiday. Back toward home (and work) on Friday.
I finished my Frugel Horn MK3 build about 2 months ago, but still haven't hooked them up yet!
With FE126eN's?
jeff
With FE126eN's?
Enabled Fostex drivers from Planet 10, but I am too far away from them to see the number, and my memory is rather stupid sometimes......sometimers?
yup they'd be 126s
hope you get a chance sometimes soon - hopefully you'll be as pleased with the results as I was with the PP amp - even a few hours of smiling & toe-tappin' is very therapeutic
hi I just hook up my simple pp last night all of tubes lid up except 2 of 12at7eh and the music volume so low and distort I try connect without feedback its louder but still distort. I check my wiring over and over and couldn't find what's wrong.pls anyone tell me where to look.
thank you in advance
nate
nate
Do you mean your running it with those EH 12AT7 that don't light up? If so check in very dim light. Maybe they are the problem. What are your other tubes in the amp? Brand etc?
Are you running Pentode , Triode , or UL. What Transformers? Good to check to make sure Primary wires on Outtput Trans are hooked up right (eg. Not Reversed)
Good to check for correct voltages at tube sockets from top. Be carefull! One hand behind your back. Protect your heart!
Randy
Randy
both of12at7 are ligthing up but they are very very dim almost can't see . the others tube working fine they are jj el84 and jjgz34s they're all brand new.I tried to connect them in every modes.all of them got the same result. I'll try to measure those voltages tonight.
thank you
thank you
It's a PCB, so the heaters should be configured correctly. Some miniature tubes have very dim heaters, so that is not necessarily a problem. Having one dim tube might be indicative of a bad solder joint, but both is a bit less likely. Checking the voltage is worthwhile, though. It would be best to do it with the input tubes in place. You want to measure AC volts across pin 9 and pin 4 or 5. You should read 6.3V here.
I personally found that the EH tubes don't operate quite right in this amp, but the amp still made sound and was loud. I think you have a different problem. Mine just distorted when pushed towards its limits:
http://www.diyaudio.com/forums/tubelab/148694-tubelab-simple-p-p-31.html#post2159028
I'll do that tonite. I hope I connected my opt right.It.s edcor cxpp30ms6.6k.accord to this manualhttp://www.edcorusa.com/Manuals/CXPP30-MS-6_6K.pdfwith this schematic http://i198.photobucket.com/albums/aa160/birdy81260/SimplePPschemUL.gif
blue to L-PRI-1-2
white blue to L-PRI-1-3
red to L-PRI-1-1
white brown to L-PRI-2-2
brown to L-PRI-2-1
I have 4 ohm speaker so I connect
orange to LFB1 then to positive speaker tab
white to LFB2 then neg speaker tab
If anyone can verify these connections
thank you
\nate
blue to L-PRI-1-2
red to L-PRI-1-1
brown to L-PRI-2-1
thank you
\nate
also I use edcor xpwr008-120 http://www.edcorusa.com/Manuals/XPWR008_120.pdf
i connect
red to T1 RED 1,3
blk red to T1 RED YEL 1
yellow to YEL1,2
brown to T1 GN 1,2
blk on the other side to IEC fuse and switch
i connect
red to T1 RED 1,3
yellow to YEL1,2
brown to T1 GN 1,2
no this is my first tube amp those are only opt i have.The OPT looks to be connected correctly. Have you tried a different source to drive the amp?
- More Vendors...
- Tubelab
- Tubelab Simple P-P
