Hello, I would like your opinion on building a tube preamp for my car, this is going in the head console which is something I have never seen before, each parts has to be under $50. So far I've been looking at a few ebay/aliexpress kits, let me know your thoughts, thanks.
Kits so far:
https://www.ebay.com/itm/313757694352?var=612529018280
same kit but on Aliexpress: https://www.aliexpress.com/item/2255799850275299.html?spm=a2g0s.8937460.0.0.fa832e0eg3hQZ8
https://www.ebay.com/itm/325203864221?var=514101376212
https://www.ebay.com/itm/125318368510
https://www.aliexpress.com/item/2251832832888687.html?spm=a2g0s.8937460.0.0.fa832e0eg3hQZ8
https://www.aliexpress.com/item/2251832694961293.html?spm=a2g0s.8937460.0.0.fa832e0eg3hQZ8
Kits so far:
Tube Preamplifier Board _ Kit Base on Hetian Mao's Circuit Hifi.png145.2 KB · Views: 186
1DIY LITE LS60 balanced Tube preamplifier board _ balance preamp kit.png109.6 KB · Views: 174
DC12V 6N8P (6H8C 6SN7) Vacuum Tube Car Audio Pre Amplifier HiFi Preamp Board.png144.2 KB · Views: 177
From what I remember as a kid, a lot of valves (tubes) can be microphonic if subjected to high vibration levels. Also the acoustics in most cars are pretty bad. Is it worth the effort?
We used to have car radio's - no microphonics at all; besides you're using it at line level. The most likely candidate seems to be the last one with the 6sn7.
Concerning the acoustics, these are in a car often better than at home, almost like a headphone as you are completely surrounded by it. So I would give it a try.
I don't know what kinda car you have, but mines a Mazda 2 and it has a Tang Band W5-2143 5
running on cheap Class D amp board > Fiio BTR5 and sounds pretty good, I can tell the car is not the limiting factor. I just want more musical and warmth.
The Mazda 2 below is something similar to what I have. Anyone with good knowledge on circuit I would like your opinion on which board to invest in with potential in upgrading caps etc... It's worth it! Thanks.
Car sound deadening materials will be used for this build: Siless Liner 157 mil
FYI I am a proud owner of a Yaqin MC13s/ Mullard 34B and it sounds amazing! 🙂
I'm back! 🤓 thanks for your input KeesB, I'm going to get the last one for the car "DC12V 6N8P (6H8C 6SN7)" I saw another which is quite interesting.
Let me know what you guys think, the seller recommended these transformers:
https://www.ebay.com/itm/164561307729
However I'm wondering if there's anything better that would improve the sound, what transformer and 6Z4 tubes do you recommend?
Hifi 6Z4 +12AX7 SPreamp Board /Kit Base on France JP200 Preamplifier:
https://www.ebay.com/itm/164561341392?var=464128057395Let me know what you guys think, the seller recommended these transformers:
There's something wrong if you say transformers...in a car!
Probably you want to install a DC/AC converter, so 12 VDC>120 AC then Transformers!
An elegant way is to take power for HT directly from 12 V DC and use a switching circuit to elevate potential to 200-300 V.
But you don't need it!
The warmth & sweetness of the sound don't depend on the particular circuitry, well, substantially you would want to use transistors where they're needed ( line level) and tubes for power.
The second one is not going in the car.. It's for home. So you can recommend some parts.
The 7 pin pentode 6n1 or 6n3 is about 1 inch tall easier to fit 2 into the head unit as opposed to 12ax7. A small buck boost circuit can do the B+ of 40 to 50v. The 12v may work for line levels.
- Tubes / Valves
- Tube preamp for car
